Suggested Sources for Engine bearings??
Started by kj4821, November 28, 2011, 12:35:11 AM
kj4821
Can anyone suggest a source for oversized main bearings for my 1990 Cadillac Fleetwood (front wheel drive) ?
VIN 1G6CB1336L4274368
Engine is 4.5 Liter
Here is what I am looking for:
An oversized #1 Main Bearing which was identified by a blue edge color on the original GM part.
An oversized #5 Main Bearing which was identified by a black edge color on the original GM part.
Thanks for your help!
Can we assume you have tried a GM dealer, if so and they are discontinued, I am sure Napa has engine bearings, you just need to focus on the under/oversize of course..  Why are you replacing just 2 bearings, is the for the noisey number one main?
kj4821
Hi and thanks for replying!
Yes these parts discontinued long ago at GM dealers.
Reason for replacing is of course to correct the #1 main bearing knock.
Engine has high milage and I am thinking that I will need the oversized bearings for #1 and #5.
In the aftermarket replacement parts market, bearings generally come in .0100"
increments, for re-ground craks, while the factory had .0005" increments.
Any idea where I might find these OE versions?
#3
You will not need #5, that was never an issue, number one wore because of the common practice of over tightening the belts, I would check Napaonline for the proper bearing,  you need .001, and .002  over/undersize. to correct the thumping in the front of the engine, which btw was a customer complaint but really did affect the engine. When the pan is off you must plastigage #1 to determine which bearing you need, to do this you must get upward pressure on the crank to get an accurate reading.  Napa does have sets in 001 and 002 over/undersize.
kj4821
Understood. I am very grateful for you sharing this with me  :)
Quote from: kj4821 on November 29, 2011, 11:23:48 PM
Your welcome, always feel free to ask for advice, the people here are the best.
CEC #20099
DJAKES
I have a 90 SDV 4.5 V8 .If you are pulling the engine just for the bearing knock, don`t waste your time. Mine had bearing knock at 65K, & it still has it at 171K. Use 10w-30 oil, not 5w-30, & don`t use Mobil 1. Use GM oil filter, or better.
This is NOT a function of belt tension- it is a serpentine setup with a spring tensioner.
The big problem you might have is a leaking front seal & pan gasket. I fixed that by ignoring it, & washing the engine & driveway occasionally. Don`t misdiagnose PISTON SLAP for main bearing issues. These engines had it, on cold start.
Of course, if you have torn down the engine & are rebuilding it, GOOD LUCK, you will need it.....
c chleboun #20099
