53 series 62 COUPE
Started by jst, February 19, 2012, 03:37:48 AM
jst
Hi
About half way into my 53 coupe restoration
JST
CLC #27640
USMC  63-68
1953 Cadillac series 62 COUPE
Jim Beard
Calvin Jones CLC # 18955
Nice.....just completed 53 Coupe DeVille
jst
Hi
A little bit further.
JST
CLC #27640
USMC  63-68
jst
Next phase with continental kit almost done
JST
CLC #27640
USMC  63-68
P W Allen CLC# 20193
Paul
53 Coupe
Twin Turbine
jst
Outside finished
CLC #27640
USMC  63-68
broadcreek
Nice job Joe. I'm just starting on the same model Caddy. Do you have a favorite parts supplier? Any one you'd recommend for front bumpers?
EdL
jst
Hi Ed
Sorry for not getting back to you earlier. I would highly recommend Eddy Jones near Minneapolis MN. His number is
612-558-2629. He has a barn full of parts plus two 53 parts cars. Eddy is very reasonable, price wise, and just great to deal with plus, he is a wealth of information and will help you out. Aside, could you tell me about what temperature your 53 runs at and if you have any heating up problems ? Mine runs hot !
JST
CLC #27640
USMC  63-68
broadcreek
I've had a couple of Caddys with that problem. I usually start out by changing hoses, thermostat and water pump. (Also check timing.) But I did have one that I had to pull the motor, strip it to a bare block, pull the freeze plugs and use a high pressure hose to flush out the cooling passage ways. I couldn't believe the gunk that had built up in there. Hopefully, you won't have to go through that.
jst
Inside now done
Joe T
CLC #27640
USMC  63-68
D.Yaros
Very nice!  Someone did great work, and it shows!
Dave Yaros
CLC #25195
55 Coupe de Ville
92 Allante
62 Olds
57caddy
