WANTED 1956 Cadillac drivers door stricker plate.
Started by dino, April 16, 2012, 10:18:30 AM
dino
WANTED 1956 Cadillac drivers door stricker plate.  Mine is a bit worn..  Would like to buy a NOS or a real good used one..  Also does anyone know if the stricker plate from the drivers side rear door of a 4 door is the same as the one used on the front door ?
D.Martini
1954 6237DX  CDV
1956 6267X  CCP
1960 6267X  CCP
M. Bankes
Hi,
I can say they are the same for either the front or rear door, I've got both 2 doors and 4 doors, and can't see any difference. The only difference is either a right or left, but there's no diffence between the front or rear door ones.
If you decide to go used a have a decent pair I just listed - E-Bay # - 180863601121
Mike Bankes
brian faull clc#25881
The master parts book shows the drivers side striker plate (466 4972) should be the same from 1950 to 1956 except for 6239dx. Oddly it shows the passenger side striker plate (466 4971) is the same only for 1954-1956 except for 6239dx. Hope that helps.
