68 transmission kickdown lever and spring
Started by Dan M, November 01, 2012, 01:24:17 PM
Dan M
These 2 parts are at the carburetor on the drivers side and actuate the kickdown switch itself.
I also need the dashpot which is located on the same bracket.
Thanks in advance.
Dan at 603-458-5013 eastern evenings
Rob Troxel
If you can't come up with these hard to get parts, you might consider adapting a kick down switch from a 69=70 Cadillac.  They work better since they are a lever switch that activates against the throttle lever movement.  The original ones on the 68  were problematic as they had a square inset connected to the carb shaft that would often break.
60eldo
  I think I have one,,email me  ,,,jkcarrrremail addresses not permitted
Jon. Kluczynski
60eldo
  Dan I took pics of my carb and sent them,,,hope these are OK
Jon. Kluczynski
