CARB KIT NEEDED
Started by linchero, January 20, 2013, 10:13:45 AM
linchero
Any idea were to get  the carb kit for my 60 eldorado three carb set up rochesters ?looking for the complete set for all three thanx.
Don't buy NOS or anything older than a couple of years old.  I had my center carb rebuilt 2 years ago and brought a kit to the rebuilder with the carb thinking it would be a plus.  He told me that older kits have gaskets that would be eaten up by modern fuel.
Kits are still available new for these and I would go that route.
Brian
D.Yaros
Dave Yaros
CLC #25195
55 Coupe de Ville
92 Allante
62 Olds
linchero
im missing the front tag on the carb I didnt look to see if the other two are matching numbers what do you think are they all the same numbers ?  by the way in my small town there is a gas station thats ethanol free extra money who cares no corn.
D.Yaros
I wquld be more than surprised of all 3 carbs were matching.  Perhaps the front and rear match, but the center might be different.
Give Daytona Parts Co. a call.  It can definitively answer your question.
Dave Yaros
CLC #25195
55 Coupe de Ville
92 Allante
62 Olds
J. Gomez
The Rochester tri-pack would be the 2G and 2GC type, 1960 carb numbers are listed in the attached file.
Good luck..!
J. Gomez
CLC #23082
The center carb is totally different.  The outboard carbs do not have adjustments for idle/air, etc.  They are either full open or closed as the linkage moves to the open position on full throttle when vacuum is directed to the secondary diaphragm via the vacuum switch mounted on the center carb and activated by depression of the throttle linkage.
My 9th grade English teacher would have hated that sentence.
Brian
David King (kz78hy)
I stopped by Daytona Carb while at the Grand National last year.  Bought a complete rebuild kit for my 58 tripower, even bought a spare float, just in case.  Your fore and aft carbs are the bigger than the 58, but I'm sure they will know right away what you need.  They have their own supply base for material and it is first rate.
For a few dollars more,(lots), they can rebuild them to be perfect.
David
David King
CLC 22014  (life)
1958 Eldorado Brougham 615
1998 Deville d'Elegance
1955 Eldorado #277
1964 Studebaker Commander
2012 Volt
CLCMRC benefactor 197
Jay Friedman
Another good source of carb kits is the Carburetor Shop in Eldon Missouri.
1949 Cadillac 6107 Club Coupe
Decatur, Georgia
CLC # 3210, since 1984
60eldo
    You can buy the tags new still
Jon. Kluczynski
linchero
man you guys are  fully informed im impressed at the quickness that i received for the info on the carbs. I will use this info . thank you very much.
linchero
I forgot I have one more question were can I get the switch thats in the center ?  thanx
Tough part to find but they turn up on eBay.
Also google master mind inc. He has them.
linchero
well I got the carb kit for the center carb,from daytona carb. would you believe all three  carbs are original ?
brian faull clc#25881
I have new carb kits for the tri power. The outside carb kits are $52.00 each and the center kit is $45.00. New floats are $12.00 each. If you still need anything let me know. Thanks, Brian. 412 952 6027. cadillac32v@hotmail.com
