Looking for mounts that will allow chevy 350 motor into a 1960 couple deville
Started by 60Cadillac Syndicate, March 06, 2013, 10:17:07 PM
Hello all I'm trying to put a 350 chevy motor into my 1960 Cadillac anyone have fabricated mounts for sale that will allow it to go in easier? Any info would be great!!
Dan LeBlanc
First question is why?  A Chevy 350 is going to struggle to do what the Cadillac 390 did.
Dan LeBlanc
I had a 454 and TH400 in my '60 CDV, and when I replaced it with a '61 390, and '60 Hydramatic, it was a far better vehicle.  Both driving and handling.
The 390 had hands down more torque, and it is the torque that moves the car, and combined with the low 1st. gear of the Hydramatic, it really got off the line a lot smoother, and with less effort.
Plus, the added weight of the Cadillac Engine and Trans, like 200 Lbs, really helped the front suspension to work as it was designed to.
Dan LeBlanc
I'm not a purist by any means and if there's a better power plant out there for the car then great.  A 350 is simply not the way to go.
Dan LeBlanc
Here's a better place to get the info that you seek:
http://www.modifiedcadillac.org/forum/index.php
These guys will know exactly what you would need.
I would do something other than a SBC if you can.  It's torque that moves a heavy car, not high revs.
Brian
Dan thats what I have and the car isn't stock thanks for your input eventually I will put a bigger one in
Thanks 76eldo
Yes, sometimes one has to use what one has at hand.
And in this case, anything to get the car on the road is better than letting it rust away.
The conversion can be done without destroying any of the originality of the original vehicle, and when the time comes, it can all be put back to "normal" as I found when I did mine.
