leaking top on 76 eldorado convertable
Started by brico185, March 26, 2013, 04:53:21 AM
brico185
i have just installed a new rear window in my caddie but in rain the trunk fill with water any one got any ideas why or what i have done wrong?
many thanx brian Coakley
G'day Brian,
You will find that the drain which is made out of top material will have a hole in it.
The best way to find out where it is, is to hop inside the trunk, close the lid and have a friend with a hose wet the top down.
Make sure the friend has the trunk key so he, or she can let you out, because as soon as the water starts, you will be yelling out to turn the water off, and let you out.
