1978 Cadillac Eldo Custom Classic Biarritz
Started by Dan Marinola, September 21, 2013, 03:06:04 PM
Dan Marinola
I'm looking for the upper passenger inside door panel for my car. It is the cream color that goes with the Arizona Beige on the lower part of the car. Anyone have a good used one with no cracks? Thanks,Dan Marinola CLC#4140
Daniel P. Marinola
joecaristo
If you can't find a good used one, I sent my upper door panels to just dashes and they did a great job. The grain is a little different but they use the same process as original. Even if you find a good used one and dye it, it will still crack. For some reason the lighter colors crack more. My car is white and I bought it in 1984 and it was cracked then!
Joe
Joe Caristo
Dan Marinola
Thanks for the reply Joe. I know I was taking the proverbial shot in the dark but I had to give it a try. I had mine fixed a couple of years ago but the vinyl is brittle now more than before. I will give just dashes a call. Thanks again! Dan Marinola
Daniel P. Marinola
