WTB, high-speed crank case ventilation tube
Started by Cooke, October 08, 2013, 09:11:48 AM
Cooke
I need this metal tube that runs from the back of the air filter box to the top of the valley pan on a 1938 (maybe other years) 60S. It runs the crankcase vapors to the carb basically. Thanks, Martin 860 301 9621 or PM me.
harry s
Martin,  That tube is about 1/2" OD as I recall and can be fabricated from like sized steel tubing  like fuel line. I think I read in an earlier post Joe was going to send a picture. The engine end of the tube goes through a grommet in the rear valve/valley cover then comes up and makes a slight bend toward the firewall and then bends 90 degrees level with the opening in the air cleaner which has a clamp to hold it in place.     Harry
Harry Scott 4195
1941 6733
1948 6267X
2011 DTS Platinum
joeceretti
I know this isn't the Technical-Authenticity forum but does anyone have a photo of the grommet? I suspect Martin is missing his and I for sure am missing mine.
