Correct windshield washer jar for 56 Sedan Deville?
Started by smilasm, December 23, 2013, 11:29:00 AM
smilasm
Hello again  :),
at this time I need help with the correct windshield washer jar for my Sedan Deville 1956. Both of them are on ebay and description says they are for 56 Deville, but they are not the same. Which one is correct? Maybe somebody have the correct one for sale?
http://www.ebay.com/itm/370956339396?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
http://www.ebay.com/itm/251404446465?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
Also I need windshield wiper vacuum motor and center pulley for same 56 car. Are they same on 57 Cadillac?
Thank you in advance
Marius Smilas
Marius Smilas
1956 Sedan DeVille  http://bit.ly/1hsWhri
62 driver
Search, "1955 washer jar" here.  The red top one is mine and I asked the same question. Some one said it for a 1954-55 only. I don't want you to buy the wrong set-up as I have done so in the past. Dave
Dave Schneider,  CLC #27889
smilasm
Ok, thank you. Maybe somebody have some pictures how should look the correct one for 56?
Marius Smilas
J. Gomez
Marius,
The 1956 are none-electric type, so the first listing is not the correct one, the second one looks to be the correct one.
The crankshaft pulley is the same for the dual type from 1952-1956 and triple type (A/C cars) from 1954-1956 per the MPL.
Are you referring to the vacuum assist pump which connects to the oil pump? If I recall these are compatible from 1956-1958. If yours is missing just make sure you get hex key that drives it.
Good luck..!
J. Gomez
CLC #23082
smilasm
#4
Sorry Jose my mistake,I am talking about wiper vacuum motor and wiper center pulley  :)
Marius Smilas
Marius Smilas
Marius, the pulley for the wiper motor is specific for 1956. If interested, I have a NOS wiper motor for 1956; it may be a little bit expensive. If you have a tired wiper motor, the wiper man can rebuild it. Sorry, I don't have the pulley.
smilasm
Thanks Roger,I don't have wiper motor and pulley at all, they are burned out on my car.The center pulley it's specific for 56 and what about wiper motor?Send me please a pm with the price you asking for wiper motor.Maybe you also have the part, I don't know the name but it should hang by the wiper motor,where four small hoses are connected?Also I need a t-joint for heater hoses by the wiper motor,don' know the name too ,still waiting for parts book :).
Thank you
Marius Smilas
Marius Smilas
Marius, as the wiper motor is in my store room, I will look the price the next time I'm there. The T junction for the heater hoses can be done with a tube and some welding or silver soldering.
The pulley for the wiper is an assembly with the base plate. This plate is attached to the car's body and the wiper motor is coming on top of the plate.
I suppose you are also missing the vacuum manifold, see the attached pictures.
smilasm
Yes,I am missing this one,vacuum manifold.Also vacuum parts on distributor and throttle linkage,plastic hub on throttle linkage.
Thank you
Marius Smilas
smilasm
And Roger,what is the vacuum part on the top of the first picture,the hose connected on,it is visible only part of it?
Thank you
Marius Smilas
It's the windshield washer coordinator. I just know that this element is not included with the wiper motor I have.
It seems that you are missing a lot of parts!
smilasm
Yes Roger,everything around that place burned out.
Marius Smilas
