1947 Flathead Oil Pressure
Started by Jeff Trahan, November 22, 2014, 07:49:27 PM
Jeff Trahan
I changed the oil to Valvoline 20W-50 racing oil and the lifter tick stayed the same. So I guess I need to take the lifter blocks out and check for any blocked passages and check the 3" measurement. The question now is this: is the lifter noise harmful to the engine or just annoying? Should I not start/drive the car until I get time to disassemble the lifter blocks?
Jeff T.
Jeff Trahan
#28564
1938 Cadillac V16 9033
1947 Cadillac 62 Convertible Coupe
1958 Cadillac Biarritz
Steve Passmore
Its going to depend on which part is not getting oil if that is indeed the problem. If its the plunger not getting oil or is just stuck that will be just like driving with a noisy tappet but if the lifter body is not getting its oil from the lifter block that could be more series.
Steve
Present
1937 60 convertible coupe
1941 62 convertible coupe
1941 62 coupe
Previous
1936 70 Sport coupe
1937 85 series V12 sedan
1938 60 coupe
1938 50 coupe
1939 60S
1940 62 coupe
1941 62 convertible coupe x2
1941 61 coupe
1941 61 sedan x2
1941 62 sedan x2
1947 62 sedan
1959 62 coupe
Jeff Trahan
Does the fact that it's quiet when cold but noisy when warm (tick starts after about 15 minutes of idling) provide a clue of what part is not getting oil?
Jeff Trahan
#28564
Steve Passmore
Not really to me because I was asked to look at a fellow club members car about 4 months ago with exactly the same symptoms. Nice and quite when cold but would tick its head off as soon as it warmed up. I assumed worn lifters that would leak worse when the oil warmed and got thin but the problem was just one plunger frozen solid.     A new set cured it instantly but I don't know why it gave those symptoms.
Steve
Present
1941 62 coupe
Previous
1936 70 Sport coupe
1938 60 coupe
1938 50 coupe
1939 60S
1940 62 coupe
1941 61 coupe
1941 61 sedan x2
1941 62 sedan x2
1947 62 sedan
1959 62 coupe
Bobby B
Quote from: Steve Passmore on September 03, 2016, 07:00:41 PM
Steve,
  I think that even the slightest valve train noise sounds horrible in a Flathead because it gets amplified and not dampened by the proximity of the metal valley covers. All it takes is one bad apple.....
                                                             Bobby
1968 Mustang Convertible
1973 Mustang Convertible
1969 Jaguar E-Type Roadster
1971 Datsun 240Z
1979 H-D FLH
Steve Passmore
Steve
Present
1941 62 coupe
Previous
1936 70 Sport coupe
1938 60 coupe
1938 50 coupe
1939 60S
1940 62 coupe
1941 61 coupe
1941 61 sedan x2
1941 62 sedan x2
1947 62 sedan
1959 62 coupe
