Turn signal fluid
Started by tturley, November 07, 2015, 03:09:14 PM
Quote from: David Greenburg on November 09, 2015, 07:52:42 PM
Just imagine if Lucas had been making digital dashboards in the '80s!
They did I believe in the Lagonda?  A disaster for restores now.
Philippe M. Ruel
For its lighting systems, Lucas' nickname could be "Prince of Darkness".
1952 60 Special in France.
Jay Friedman
When I worked in a garage as a young guy in the '50s, the older mechanics would tease newbies and sometimes even customers who asked what was wrong with their car by saying "the Johnson Bar is broken" or "the Finnegan Pin is bent".  Later in life I learned that while the Finnegan Pin was a non-existant "thing-a-ma-jig", there really is an obscure tool called a Johnson Bar, apparently a kind of pry bar used to extract screws.
1949 Cadillac 6107 Club Coupe
Decatur, Georgia
CLC # 3210, since 1984
savemy67
Hello Jay,
Ask any stevedore or longshoreman what a Johnson bar is and they will probably tell you about the blisters they received from using one.  In the shipping and freight world, a Johnson bar was a long (usually wood) pole with a short, offset tab or lip at the bottom end.  The bottom of the bar also had a pivot or fulcrum.  Thus configured, the bar provided alot of leverage to maneuver shipping crates, pallets, etc. that weighed hundreds of pounds.  Back in the day, a man and his Johnson (bar) could move mountains!
Christopher Winter
Christopher Winter
1967 Sedan DeVille hardtop
Jay Friedman
Chris,
Thanks for the enlightenment.  Now, if someone could only come up with a real Finnegan Pin.
Decatur, Georgia
Quote from: savemy67 on November 11, 2015, 09:33:10 AM
Ask any stevedore or longshoreman what a Johnson bar is and they will probably tell you about the blisters they received from using one.  In the shipping and freight world, a Johnson bar was a long (usually wood) pole with a short, offset tab or lip at the bottom end.  The bottom of the bar also had a pivot or fulcrum.  Thus configured, the bar provided alot of leverage to maneuver shipping crates, pallets, etc. that weighed hundreds of pounds.  Back in the day, a man and his Johnson (bar) could move mountains!  Christopher Winter
In the Boat Yard, we called those things Red Neds, as they were painted red.   A great lever
cadillac ken
another boatyard tool was the "bung picker".  As a kid we would laugh and laugh at this.  Apparently it was a pointed hook thingie tool that would pick the bungs out of the wood on the boats (kind of foggy on the explanation as we always were laughing when the guy at the boat yard would mention the tool.)
savemy67
Hello Ken,
A bung is typically a stopper for a hole.  In the boatyard, a bung is usually a stopper for a drain, and one would have to pull the bung to let out the water.  I can appreciate the laughter.
Christopher Winter
Christopher Winter
Im going to guess the reason you would be removing bungs in a boat yard would have to do with ballast tanks?
The only bungs in a boat yard worth thinking about removing is those in the hull to let the bilge water out, and the one in the barrel to let the rum out.
chrisntam
I used to work in an auto parts store back in the '80s.
We kept the turn signal fluid next to the oscillating Johnson rods & muffler bearings.
:o
1970 Deville Convertible
Dallas, Texas
