1957 Cadillac rear speaker wiring??
Started by Cadillac Jack 82, March 17, 2016, 02:24:10 PM
Cadillac Jack 82
Does anyone have a wiring diagram for the rear speaker in a 1957 Cadillac?  The shop manual doesn't really have anything I can go off of.  I plan on replacing my rear speaker soon.
CLC Member #30850
1934 Harley VD 74ci "Rosie"
1948 Buick 76S "Lillian"
1950 Cadillac CDV "Doris"
1959 Cadillac CDV "Shelley"
Past Cars
1937 LaSalle Coupe
1955 Cadillac CDV
1957 Cadillac Series 62 Coupe
1964 Cadillac SDV
and a bunch of others...
If you are replacing an existing speaker there will be one plug that connects to the speaker and another wire that goes to a body ground.
If you need to run a new wire you can use the factory wiring trough on the passenger side by remo ing the sill molding and lifting he carpet if it's the same as 1960.
Brian
Cadillac Jack 82
Thanks Brian.  The current speaker (which is dead) has one green wire with a male connector that connects to the speaker.  There aren't any other wires that are attached.  I assume this is the power lead and all I would need to do is ground the other?
CLC Member #30850
Past Cars
1937 LaSalle Coupe
1955 Cadillac CDV
1964 Cadillac SDV
Walter Youshock
Car body is ground.  You'll see that alot.  Dash lights are single positive wire since the whole dash is ground.
CLC #11959 (Life)
1957 Coupe deVille
1991 Brougham
Cadillac Jack 82
Interesting so the one wire to the speaker is all that I need to get it working again?  Be nice to have the dual speakers working again
CLC Member #30850
Past Cars
1937 LaSalle Coupe
1955 Cadillac CDV
1964 Cadillac SDV
Walter Youshock
That's it.  Remember your dealing with a 60 year old tube radio that was probably never recapped.
CLC #11959 (Life)
1957 Coupe deVille
1991 Brougham
