Gas Problem
Started by GRH, September 09, 2016, 12:45:55 PM
Best to pull it out of there and inspect.
If ends dished and/or cam will have scars you got problems.   Can easily measure length.
Are you sure pump was put back correctly?
Most after work problems aren't due to wear.   Like they didn't seat the actuator arm on the shaft.   It has to be in correct position.   It was probably living on syphon, until you changed grade.
DaveZ
Quote from: cadillacmike68 on October 27, 2016, 08:59:57 PM
Timing retarded, not advanced will cause it to run hotter. Advancing the timing helps cool the engine but brings its own set of issues.
Yup, duuno how I got that backwards:-(
Dave
David Zitzmann
1932 345B
33 LaSalle
  Ron, the fuel push rod length is 3.1225" long x .370 diameter.
I had problems starting my engine after a complete rebuild and finally tracked it down to the carb.
I had it rebuilt by a well known company in Detroit, it was their first rebuild on a '32-'33 carb and
they used mine as a prototype to build and sell new carb kits for these years.
After much frustration I was able to determine that they had made the float slightly oversized and
it was impeding the gas flow into the carb. It (the float) was sanded down slightly and has performed perfectly
since.
So, if you had your carb rebuilt or installed one of these carb kits check that the float isn't interfering
with the jet.
Hope this helps
Andy
Andy Smith  CLC 24270
