verify matching numbers
Started by caddylover, November 05, 2016, 05:51:46 PM
caddylover
Hello Everyone. I am brand new to this site and need some help. I will be looking at a 1965 coupe soon and need to know how to verify that the engine is original to the car. I am assuming the VIN tag is on the drivers door. Not sure where on the block the numbers are located? Your help is greatly appreciated.
Ralph Messina CLC 4937
Welcome aboard. If you're not already a member, there's great benefit to joining the club.
The engine number is located on a flat surface of the engine block in the valley just above the transmission bell housing. It should be the same as the Vin number on the passenger side chassis rail a bit forward of the alternator location. The correct number should be "J51xxxxx"
Ralph
2018 GMC Yukon
caddylover
Quote from: Ralph Messina CLC 4937 on November 05, 2016, 07:52:55 PM
Thanks Ralph. Sounds like the one in the valley area will be hard to see but now I know where to look! Many Thanks.
I am definitely considering membership I guess it depends on how deep I get into the Caddy's!! I currently have a 72 Nova that has been my focus but that could change.
Von
Von
Chuck Swanson
I needed the Allied Vaughn build sheet to verify my '65.  The VIN and engine serial number were listed on the build sheet in different columns and both matched my car, but the number were not the same.   However, I am looking at the number under the drivers side head by firewall.  Chuck
CLC Lifetime
AACA Lifetime
66 Sedan DeVille hdtp
66 Calais pillar sedan
66 Series 75 9-pass limo
65 Fleetwood
07 DTS w/ Performance pkg.
69 Dodge Coronet R/T
Hi Chas,
The number below the driver side head is the Engine Unit Number. It designates the sequence in which the engine was assembled which is not necessarily the same as vehicle assembly. It is used to track components used in, or running changes to the assembly.
HTH,
Ralph
2018 GMC Yukon
