How to set the chokes on updraft carbs
Started by Stinson, January 16, 2017, 09:53:33 PM
Stinson
Hello, I have updraft Zenith carbs on my v-12 engine and apparently the chokes are not properly adjusted because the car will not initially start unless starter fluid is first used. How do you adjust them.
Thank you,
Ty Stinson
Ty Stinson
CLC22330
Jeff Rosansky CLC #28373
#1
I have no idea how to set the choke, but I would like to offer an opinion.
After reading your other post, it appears she won't start without a shot of starting fluid.
As you have tried other things and are looking at the choke last makes me think you suspect another problem. I am of the fix one thing at a time and verify you haven't made the problem worse school of thought. May I suggest you not try to adjust the choke at this point but just eliminate it from the equation.. If you just manually set the choke at various points and see if it starts then that may eliminate it. If adjusting the choke doesn't  help then your problem lies elsewhere. My concern would be messing up the choke and adding another problem to the mix. If you just disconnect it and move it manually thru its range while starting and it doesn't help then all you have to do is re hook it up.
Just a thought.
Jeff Rose
Stinson
Thank you Jeff, I will try that. But, it may be difficult because there are two updraft carbs and when I disconnect the rods wonder how I will know when the flaps are open or closed.
Ty Stinson
Ty Stinson
CLC22330
Steve Passmore
Quote from: Stinson on January 16, 2017, 11:36:05 PM
Ty Stinson
That's what I thought. Very tricky on two up draughts on the V12 engine and one can't see them both at the same time.
Is the choke arrangement the same as when the original carbs were on there Ty? If so, all you can do is follow the manual on adjustment.
Steve
Present
1937 60 convertible coupe
1941 62 convertible coupe
1941 62 coupe
Previous
1936 70 Sport coupe
1937 85 series V12 sedan
1938 60 coupe
1938 50 coupe
1939 60S
1940 62 coupe
1941 62 convertible coupe x2
1941 61 coupe
1941 61 sedan x2
1941 62 sedan x2
1947 62 sedan
1959 62 coupe
Stinson
Hello Steve, I think so. The same rods are used and only short arms added at the carbs.
Ty Stinson
Ty Stinson
CLC22330
Stinson
Quote from: Jeff Rose                                         CLC #28373 on January 16, 2017, 10:19:05 PM
Just a thought.
Thanks again Jeff, I will try doing that tomorrow.
Ty Stinson
Ty Stinson
CLC22330
