#1622985 1985 Eldorado HT4100 Oil Filter Bracket Seals
Started by tradow1, August 16, 2017, 07:45:43 PM
tradow1
Hello friends,
My 1985 Eldorado Touring Coupe has just undergone a full major service on the HT4100 (engine has approximately 40K and is a remanufactured one replaced in 1998), for leaky gaskets.  These are notorious for the leaks, and we have successfully found and installed all but one set of:
GM #1622985 Oil Filter Adapter Gaskets, Square Cut
These are discontinued, and nearly extinct.  Wanted to buy any if you have and/or hear about a way to seal the area otherwise apart from the OEM part or equivalent.
Your help is much appreciated.  Attached are:  Description of gaskets and photo of car.  She deserves not to be "incontinent"!
Travis
Travis Dowell
Charlotte, North Carolina USA
 #21963
1968 Fleetwood Series 75 Sedan
1956 Sedan deVille
2023 CT4-V Blackwing
