1947 Jack
Started by 6262, August 26, 2018, 12:58:22 PM
6262
I would need a complete jack for a '47 Cadillac.
Thanks!
1962 Cadillac Series 62
1965 Pontiac Bonneville
6262
They seem to be rather rare  :)
59-in-pieces
Are you looking for a rim jack.
I thought they were for the limos??
Also, I'm told they are very very dangerous.
Have fun.
Steve B.
S. Butcher
6262
#3
My interpretation of the factory literature is that the rim jack is for all models. Please correct me if I am wrong. It is needed for a Series 62 sedan.
It is not supposed to get much or even any use at all. A friend of mine just needs it for the sake of authenticity.
Those jacks look like they are the best to keep oneself clean when changing a wheel.
As with all things, if used properly, they would be safe.
Beats getting under a vehicle to position a jack, then having to operate it, whereas using the wheel jack, and setting a jack stand for support might be simpler.
I love the Bumper Jack that came with my Eldorado.
I even have an hydraulic Bumper jack that came with Aussie supplied GM cars of the early '50's.   Pump up, then simply twist to lower.
As I said, its usability is not the prime reason of asking for one  :)
Bob Hoffmann CLC#96
Nils,
That picture is straight out of a 1941 owners manual. It's a 1941 ONLY jack. I suggest you search out what a 47 jack looks like. Probably fits 46 & 47. Contact Bill Ingler. He's a 47 expert.
Bob
6262
Gentleman, thanks for the very helpful answers.
You are right. The illustration is extracted from the '41 manual while the '47 manual shows a bumper jack (though in a single picture without any details).
I will present the gathered information to the owner of the '47 Cadillac. I assist him in finding parts from time to time.
If any of you could post pictures of the correct '47 jack I would be grateful.
6262
This is the jack found in the car. We did not consider it original to the car:
Bill Ingler #7799
Niles:  Picture below is what I believe is the bumper jack used on the 42, except the 42-75. This  bumper jack I believe was also used on the 46-60s,61,62 and 47-60s, 61 and 62 series. The 47 Authenticity manual also says 3 jacks were provided in 47: a normal bumper jack for most models,a heavy duty bumper jack for the 47-75 series and a screw type jack for the 47 commercial chassis. Those of you who have used the rim type jack I am sure will agree it is a dangerous jack but there are also some cautions on using the bumper jack. Make sure you set the parking brakes, block the car wheel diagonally opposite the tire being changed and position the jack just inside the bumper guard( or bracket) with the shaft of the jack slightly towards the center of the car. Sometimes when a rear wheel is changed and the wheel is off the ground, removing that wheel,with the loss of weight from the tire, will cause that rear spring too move that spring shackle upward causing that side of the rear of the car to ride high.   Bill
r2law
Bill Ingler's photo looks to be the correct jack.  I have 47 6269 SDN.  Attached are pics of my jack. I'm the 4th owner of the car and I'm sure it's the original.
The base of the jack bears patent no. 2400235.  Attached is a copy of the patent. It was granted on May 14, 1946.
Good luck in your search.
Bob Hoffmann CLC#96
Nils,
I may be able to help. Please contact me directly at bobscads@comcast.net so I can send you some pics.
Thanks, Bob
6262
Bill, r2law, many many thanks, this is very helpful!
Bob, I have written you an E-mail.
6262
I am still searching for a jack. Should have the patent number for proper identification... Thanks!
Bill Ingler #7799
Niles:    My 47 jack base has 2400235 as the patent number and 2433537 as the patent number on side of the jack.   Bill
6262
Bill... thanks! This matches the number given by r2law. So I want a jack with this number.
6262
I am still searching...
6262
I want one for Christmas  ;)
Bobby B
Quote from: 6262 on December 02, 2018, 10:06:49 AM
And for Christmas I'd like a single bezel window switch cover for my '47.....1947 Cars are tough to find parts for. Had I done my Homework, it would not be one of my choice cars to own, for that reason. Good Luck!
                                                              Bobby
1968 Mustang Convertible
1973 Mustang Convertible
1969 Jaguar E-Type Roadster
1971 Datsun 240Z
1979 H-D FLH
Bill Ingler #7799
