Which end does the Heater hose plug into the Heater control valve on a '56 CDV
Started by Wacco65, December 09, 2018, 03:48:46 AM
Wacco65
Which end does the Heater hose plug into the Heater control valve on a 1956 Cadillac Coupe deville?
J. Gomez
Quote from: Wacco65 on December 09, 2018, 03:48:46 AM
From the Service Manual Section 16 Fig 16-B-1, from the water pump to the lower end of the heater valve the top end goes to the “T” to both LH and RH heater cores.
Reversing these may cause the valve to open from the pump pressure causing water to flow to the heater cores.  :(
Good luck..!
J. Gomez
CLC #23082
