1974 Eldorado 500 cid Engine and transmission - running!
Started by andysarcade, December 19, 2018, 03:04:15 PM
andysarcade
hi all..
Need an engine and transmission? I've pulled the one from my car because it has rod knock. The engine has been rebuilt in the past decade or so, it is super clean inside. pans are new, transmission does not leak. Flywheel is cracked but works. I replaced lifters/rockers/pushrods recently. It does not smoke at all and never has trouble starting or running.
I have driven hundreds of miles in this car and it pulls great, it just does not sound great. Transmission has no issues at all.
I couldn't face the cost of a rebuild job so i decided to swap a whole known-good setup into may car. If nothing else the transmission is good!
Its located in Campbell CA for pickup only!
Let me know if you want it - pay me what you think its worth. It can be loaded into the bed of your vehicle no problem.
1974 Eldorado Convertible
James Landi
Do you have an oil pressure reading on this engine.... at various rpms?
andysarcade
No readings nope (no gauge in the car), there were no problems with oil pressure when i was running it.
