1966 deville convertible
Started by spolij, December 25, 2018, 12:18:06 PM
mario
The tilt lever on my 68 tilt column was threaded on the tilt mechanism. IIRC the turn signal lever also. They both unscrew. The collar is a press fit over the column itself. I used a slide puller to pull off the housing from the column. That is why the housing is rolled at the top. You do not have to take the buttons off. They are so old, if you get them off without them breaking, they will be so distorted they won't fit properly again. Good luck. Stay safe and go slow.
Ciao,
Mario Caimotto
Ralph Messina CLC 4937
spolij
Thanks Ralph and Mario. The two lever's unscrewed. I never even thought of that. I don't have a puller for that and the local stores don't either. So i'm going to wrap it in the car.
thanks again
Caio
spolij
Practice pieces . Covering the steering wheel in leather. Waiting for a needle for leather.
spolij
#104
Covering dash in leather.
making a new button
spolij
So here it is over a year later and i'm finally updating. Every thing is working now except the climate control. Summer will bring a new top. The car is dissasembled ready for cleaning, minor body work and then paint.
spolij
#106
Here it is over a year and a half and i'm finally updating. Everything works now except the climate control. Spring will bring a new top.
spolij
Center button
