A/C cutoff relay wiring harness 1987 to 1992 Brougham
Started by BigWilly1965, February 10, 2019, 08:06:51 AM
BigWilly1965
Anyone have a wiring harness that plugs into the relay (part # JD141P3).  The wires on my 1990 Brougham have melted together.  I need at least a foot of the wires so I can pigtail them .
79 Eldorado
BigWilly,
Try looking at a Google image search for the relay PN and then look until you see what seem to be the mating connectors. If the relay pictures I'm seeing look like the configuration of your it does seem people have some repair connectors.
https://www.google.com/search?q=JD141P3&rlz=1C1GCEU_enDE822DE822&tbm=isch&source=iu&ictx=1&fir=Pwh3K3rx-SXK9M%253A%252C6WAvyvJDdylCwM%252C_&usg=AI4_-kSvsW1xdTneW_wxgos4EMCh6Fc8WQ&sa=X&ved=2ahUKEwjAmI7jr7rgAhWPv1kKHZE8BnAQ9QEwBXoECAUQCg#imgrc=pu2XfMgqYCmYkM:
You can also see if Clipsandfasteners.com has the plugs and terminals which you could assemble yourself. If you only need one lowest price is to just buy a ready made one but clipsandfasteners may have those too. Here's a link to their socket-harness-connectors section:
https://www.clipsandfasteners.com/Socket-Assemblies-Harness-Connectors-s/265.htm?searching=Y&sort=13&cat=265&show=450&page=1
Scott
