1946 convertible project underway
Started by Daniel Szydel, March 26, 2019, 11:35:35 AM
Daniel Szydel
Been busy patching sheet metal and getting the car ready for body work and paint.
The passenger fender was quite a challenge. I had to replace the inner air duct sheet metal as well as replace and old poorly done patch on the lower part behind the wheel. I decided to replace the front of the fender at the factory seam to take care of a rusted area below the headlight and many dents and a few tears.  That was quite a bit of work welding it in and I'm not sure if I would do it that way again.
The rear fender also needed a patch in the front lower part. Definitely a challenging piece to make.
And before you ask about the two tone paint, yes I ran out of grey epoxy primer so I used some leftover green!  Just had to put something on the bare metal to keep it from flashing.
I'm taking the car in for body work and paint in the next week and I'm pretty excited!
The upholstery guy had an opening in his calendar so I dropped off the seats and door panels.  He jumped right on it and is probably going to be done around Christmas.
1946 Cadillac Convertible
1931 Ford Model A Coupe
CadillacGlasses
This is awesome! Thanks for sharing the progress. I've been dealing with similar fender issues on my 49 Conv. project. Your body shell looks beautifully clean, I'm assuming you didn't have to do any work to the inner fender wells?
Good luck with body work and paint! This is very exciting to follow along
-Mike
M. Herbert
29645 - CLC West of Lake, CLCMRC Board Member
1949 Series 62 Conv. (in progress)
Daniel Szydel
Quote from: CadillacGlasses on November 13, 2020, 08:36:59 AM
-Mike
Thanks Mike
I ended up making that fender patch in 3 pieces.  That compound curve is tricky but I learned quit a bit!
There was one small spot on the driver side and three spots on the passenger side inner fender well. All things considered I'm pretty happy with how clean this car is.
benx13
1951 Series 62 - Under restoration
toybox
  Daniel ,
       Your ride is starting to come together.  I am very impressed. My 46 coup was no where near as ruff as your rag top.  Could you confirm with me that you need the chrome block around the radio buttons that is screwed to the radio case? Not the face plat that attaches to the dash face. I have both but my car is a series 61 so the later would not work for you.
        Keep up the nice work, Tim Walker
Daniel Szydel
Hi Tim I sent you a pm but this is the part I need
Daniel Szydel
It's been a while since I've updated but most of the car is painted and I'm slowly reassembling it
Daniel Szydel
Seems like everything needed to be gone through and repaired in some way. The power window switch had a broken stud so I made another.
Daniel Szydel
Made a die to stamp out the rocker support that was completely rotted away
Cadillac Jack 82
I can't wait to see the final result!
Tim
CLC Member #30850
1934 Harley VD 74ci "Rosie"
1948 Buick 76S "Lillian"
1950 Cadillac CDV "Doris"
1959 Cadillac CDV "Shelley"
Past Cars
1937 LaSalle Coupe
1955 Cadillac CDV
1957 Cadillac Series 62 Coupe
1964 Cadillac SDV
and a bunch of others...
jwwseville60
Wow! Cool car.
Its amazing that mice could live in the crankcase with dirty toxic oil.
Lifetime CLC
Daniel Szydel
Well, I should probably wrap this post up.  I finished the car at the end of summer last year and have a whopping 500 miles on it! So far no issues and Im really happy.
dogbergs
Very beautiful car and a very well done restoration.
Cheers from Sweden / Johan
-51 Cadillac serie 62 convertible, project
-64 Dodge Polara 2dHt, 1 driving and 1 for spares.
-70 Volvo 121 (Now sold after 21 years)
-63 Plymouth Max Wedge clone, project
-42 Harley WLA
-43 Royal Enfield WDCO
-33 Ford Pick up, project
Cadillac Jack 82
Quote from: Daniel Szydel on June 23, 2025, 03:45:52 PMWell, I should probably wrap this post up.  I finished the car at the end of summer last year and have a whopping 500 miles on it! So far no issues and Im really happy.
WOW!!!! She looks incredible!
Tim
CLC Member #30850
Past Cars
1937 LaSalle Coupe
1955 Cadillac CDV
1964 Cadillac SDV
Wilson09
This is a great thread. Doing the work yourself definitely adds to owner pride. You do great work! A real beauty.
