BTW 1937 Lasalle rear license plate bracket
Started by Cadillac Jack 82, April 25, 2019, 11:46:36 AM
Cadillac Jack 82
I'm in search for the brackets which attach to the rear license plate post on a 1937 Cadillac/LaSalle.  Mine is presently missing and I'd like to ditch the massive stainless steel license plate holder thats currently attached to my vehicle.  An example of what I'm looking for can be found here:
CLC Member #30850
1934 Harley VD 74ci "Rosie"
1948 Buick 76S "Lillian"
1950 Cadillac CDV "Doris"
1959 Cadillac CDV "Shelley"
Past Cars
1937 LaSalle Coupe
1955 Cadillac CDV
1957 Cadillac Series 62 Coupe
1964 Cadillac SDV
and a bunch of others...
harvey b
On my 37 i use a GM plate frame,it has a slot in the top that the top hook on the holder is trapped in,and the bottom is a small cup like clamp,i may still have a bottom holder like you have pictured,ill check later today if you want,i can try and get a picture of my setup too if you like.The plate frame is adjustable?it can be made bigger or smaller,it is in 4 pieces that slide together like a telescope?. Harveyb
Harvey Bowness
Classic
Check with the https://www.fillingstation.com/.  Maybe they have something that can be adapted.
Gene
Gene Menne
CLC #474
