1956 Series 62 minor parts needed
Started by theblurrrr, May 06, 2019, 10:25:02 PM
theblurrrr
Undoing 63 years of prior owners' bad maintenance on a 1956 Series 62 4D Sedan;
1.  Looking for the heater hose support clips (4) that go on top of the air boxes on the cowl and
2.  Looking for the spark plug wire loom support pieces that hold the left side rubber separator.
Any help appreciated!
M. Adkison
Olympia, WA
1996 Fleetwood V4P
1970 Coupe de Ville
1956 Series 62 Sedan
1992 Corvette Coupe
1994 Buick Roadmaster Estate Wagon
1967 Pontiac Grand Prix
1989 Chevy K1500 Diesel
Lexi
I have an extra spark plug wire loom holder which has been media blasted and painted correct Cadillac engine blue. I also have a tough to find coil mounting plate which the coil and loom bracket attaches to. The rubber grommets are available as new reproductions from Fusick. I would not buy old ones as they become rock hard, brittle and crumble with age. You should buy a set of 4 new ones, two for the metal loom bracket and 2 for the valve covers. Best to PM me. Clay/Lexi
cadparts58
 I can't help with the wire loom, but I have the four hose clips. They are in good shape. The mounting rivets are still tight, they have spring tension, and there is not rot on them. If interested, I'm asking $25 plus shipping. I do take Paypal. Attached are pictures. Thanx Frank
Frank Puma #10721
cadparts58
Michael,
Sent a PM. Not sure if it went thru. I'm not used to using PM's. Let me know. Thanx Frank
Frank Puma #10721
