1937 brake pedal and clutch pedal assembly?
Started by Joeys1937, July 18, 2019, 12:48:00 AM
Joeys1937
I'm have a 37 and I am in need of a brake pedal and clutch pedal assembly?would anyone know where i could get one? or hoe i could modify one thanks in advance!
Second Generation CLC member!
1937 fleetwood four door convertible in the works!
1939 fleetwood four door 9033 body number 1!! V16
also looking for a 1937-39 Opera Coupe.
Bob Hoffmann CLC#96
Is it missing whole or part?  or need work/parts like new pads/bushing/linkage?
If the whole thing;  a parts car, parts yard, or parts hoarder or won't find.   They usually follow the vehicle to the grave as not that easy/common to strip out - all recyclable steel.
I don't know if can interchange.   You'd have to research that in the old Xchange lit.
There are customizable ones for hot rods that might be made to work but a lot depends where the master is located, direction of travel, etc.
DaveZ
Is the entire thing missing or are you trying to replace existing? Seems odd that someone would take that off the car, of all things,  and lose it:-)
David Zitzmann
1932 345B
harry s
I don't know of anyone rodding a '37 but if you can find someone doing it or has done it they may be a source.     Harry
Harry Scott 4195
1941 6733
1948 6267X
2011 DTS Platinum
Joeys1937
thanks for the reply guys! I recently bought a 70 series and the whole car is there... BUT.. the guy that I bought it from disassembled the car and lost the brake pedal "shank" and clutch pedal assembly.  i recently bought a complete brake kit and installed it but now i need the pedals and now i am stumped. so now i need to get a brake pedal to get this car back on the road. hopefully soon
DaveZ
#6
Nice Car! Yikes on they guy losing the parts. I have some brake and clutch bits. I can check the master parts book and see what interchanges. Series 75 is different then the 60 etc.
David Zitzmann
1932 345B
