Smoke Machine ?
Started by Kevin Bielinski( Deceased), September 12, 2019, 07:13:02 PM
Hooked a smoke machine up to my '76 Fleetwood to check for vacuum leaks. Smoke was coming out of my cruise control transducer at the point where its bolted together. The vacuum hose connections were fine. Im thinking that the gasket in the unit must be shot. Does anyone have a source for rebuild parts for this unit ?
CLC Western Regions Vice President
1970 Coupe Deville
1973 Miller Meteor 3 Way
1976 Series 75 Sedan
1988 Flower Car
1971 Lincoln Mark III
1984 Lincoln Town Car
1989 Lincoln Town Car Signature Series
2001 Lincoln Krystal Hearse
Past Vehicles
1971 Chevy Impala
1973 Chevy Monte Carlo
1973 Mercury Capri
1986 Lincoln Town Car
1996 Mercury Grand Marquis
1983 Buick LeSabre Limited
Where were you putting the smoke in?     And it was coming out the figure 8 cover that the speedometer cables attach to?
it was coming at where the 2 plates are attached. I had the machine connected to a hose coming off the back of the manifold fitting
1970 Coupe Deville
1988 Flower Car
Past Vehicles
1971 Chevy Impala
1973 Mercury Capri
