1973 Cadillac Eldorado Convertible
Started by Joerg, May 06, 2020, 05:36:33 AM
Joerg
Quote from: The Tassie Devil(le) on June 16, 2020, 08:28:26 AM
Congratulations Jörg,
Looks gorgeous.
PS.   How bad were the parts that required replacing?
Hi Bruce,
thanks you.
Both wheel bearings with seals: now: No moving.
Both ball joints: the rubbers were porous and leaking
Rear silencer: There were 3 holes, but drilled perfectly round.I suspect for the condensation. No rust!
4 tires with white walls: The "old ones" were almost new. DOT 15/2018. I was able to sell them.
BR
Jörg
does not work - does not exist
winger888
76 Eldorado Bicentennial
79 Lincoln Town Car Collectors Series
Joerg
Joerg
Hello everybody,
I have now driven over 1000 km and almost everything works wonderfully.
For the winter I have done some work:
- Repair the antenna. It only runs in half. She drives out completely out.
- The dashboard lighting is a little too dark.
Can someone tell me if the gear indicator has lighting?
Thanks and best regards
Jörg
Cadillac Fleetwood
#44
Quote from: Joerg on July 06, 2020, 08:24:52 AM-
The shift indicator is illuminated. As part of the instrument panel printed circuit, it uses a 194 bulb. Many years ago, I was the second owner of a low-mileage 1973 Eldorado coupe. While the instrument cluster illumination was quite bright, it always seemed that the shft indicator illumination was somewhat dim.
Charles Fares
1970 Fleetwood Brougham
1969 DeVille Convertible
1989 Fleetwood
Joerg
Hello Charles,
thanks or answer.
Best regards
Jörg
Cadillac Fleetwood
I looked at the instrument cluster illumination as shown in the shop manual.  It appears that the entire cluster, including the shift indicator, is illuminated with only four (4) bulbs, and those bulbs are all near the top of the cluster.  This would account for the shift indicator appearing to be dimly lit or not lit. A change from 194 bulbs, rated 2 cp, to 168 bulbs, rated 3 cp, might make the shift indicator brighter.
Charles Fares
1989 Fleetwood
Joerg
Hi all,
here a few pictures from the last weekend: family outing
Joerg
Joerg
Hello everybody,
is there a guide to remove the watch?
Since mine is not working, I want to remove it in the winter and check / repair it.
Thank you for your help.
BR Jörg
Joerg
I believe the dashboard needs to be removed ....
I prefer to drive with a watch that doesn't work. ;)
Matti R
Quote from: Joerg on August 31, 2020, 07:44:27 AM
Hello everybody,
BR Jörg
Hi
I think 73 is same dash as in 71. You need to remove the two air outlets and then you can open two screws inside eaach outlets, and then you can pull the center piece out with the clock. Watch out for wires!
Best regards,
Matti
CLC #33333
67 DeVille convertible Sudan beige
79 Seville
64 Sedan DeVille
66 Calais Coupe
Joerg
Hello Matti,
thanks for answer!
BR
Jörg
