What have you done with your Cadillac today?
Started by TJ Hopland, May 07, 2020, 01:57:50 PM
It all went right together this morning. About 2.5 hours, start to clean up. I pulled the inner knuckle seal and used a needle grease tip to get fresh grease down into the bearing then put a new seal in.
The inner flange is a bit thinner, but also has a scalloped shape to the flange. It's this scalloping that made the new one slide right in. The full circle flange on the OEM shaft made it near impossible to roll out.
I didn't get to the drivers side yet. I'm not 30 anymore. Inspection shows no boot damage yet, so I'm going to sit on it until at least before the '25 GN.
Test drive in the morning. Also scrub the garage floor.  :P
Unless the '76 is different to the '71 and '72, the Right side axles are easy to remove.
Remove the Starter Motor, and loosen the lower shock absorber nut to nearly all the way off, and slip the Shocker bottom out as far as it will go, and the axle will slip right out.   This allows you to remove the Intermediate shaft, and then enough room to slip the axle out.   Done it many times.
That's different than we have seen before. How were the hole sizes compared to the bolts?  And was the nut the same size so the original washer worked?
I'm not sure if any of the frame changes in 73 changed clearances for getting the axle out.  From what Bruce described I would think that would work on a 73-78 too but it sounds like at least as much work as popping the ball joint.
The book says nothing about removing the starter, but it does say all the rest of what Bruce said.
The threaded stub end is slightly smaller as is the new retaining nut. I just went through my stash and located a nice thick washer that fit the shaft better. That starter is a heavy SOB when you're laying on your back under the car. I used my ball joint fork and just one hit with the hammer separated it.
G'day John,
I must apologise for giving out the wrong information regarding removing the Starter Motor.
I reread the Manual, and yes, there is no mention of removing the Starter Motor, but I can only remember the reason why I mentioned it was that every time I have had to remove the Axle was when I was removing an engine, and the Starter Motor was usually the first thing to go.
And yes, they are heavy, and awkward.   But, the best part about the removal is that they are easy as Cadillac used a wiring joiner in the loom to make removal easier.
They got rid of the connector in the starter harness in the mid 70's.   Was still there in 73 but I know they were gone by 78.   I think it was a problem area when they got some age on em.
No worries, Bruce. The job is done, well, half done, there is still another side to tackle later. That dampener coming apart was 100% of the vibration issues that have slowly been coming on. The car is smooth as silk up to 80mph now.
No connector on the '76. All straight feed wires. Again, another upgrade I want to do. I want to eliminate the fusible links and create an actual fuse block on the inner wheel well.
6Fleetwood6
Hi folks!
Currently @ Grand National-Gettysburg.  I went thru the photo booth.😎 I've included some other teasers.  If your in the area stop by spot#110 and say hi!
Current
1966 Fleetwood Brougham
1985 Seville Elegante`
Past
1999 Deville Concours
2006 STS4
1968 Oldsmobile 98LS
1968 Ford XL
billyoung
Tonight I just had to go for a ride in my 1968 Time Machine. There is nothing to compare to it.
Age 70, Living in Gods waiting room ( Florida ) Owned over 40 Old Cadillac's from 1955's to 1990 Brougham's. Currently own a 1968 Cadillac DeVille Convertible and a 1992 Cadillac 5.7 Brougham.
Cadillac Jack 82
59 has her Waldrons exhaust installed but a bad new front seal caused a delay.  Should hopefully be done this weekend.  Another two 59s should be too.  If all pans out photos will be posted.
CLC Member #30850
1934 Harley VD 74ci "Rosie"
1948 Buick 76S "Lillian"
1950 Cadillac CDV "Doris"
1959 Cadillac CDV "Shelley"
Past Cars
1937 LaSalle Coupe
1955 Cadillac CDV
1957 Cadillac Series 62 Coupe
1964 Cadillac SDV
and a bunch of others...
Cadillac Jack 82
Quote from: billyoung on June 13, 2024, 08:52:51 PMTonight I just had to go for a ride in my 1968 Time Machine. There is nothing to compare to it.
Thats a pretty baby girl
CLC Member #30850
Past Cars
1937 LaSalle Coupe
1955 Cadillac CDV
1964 Cadillac SDV
Cadillac Jack 82
Btw if anyone sees the old 55 CDV from NY please post.  Miss that gal.
CLC Member #30850
Past Cars
1937 LaSalle Coupe
1955 Cadillac CDV
1964 Cadillac SDV
Mike Baillargeon #15848
I exercised a 1955 Eldorado today....gosh I bought this one coming up on 12-13 years ago.
For those of us who can't really swing a 53 Eldorado, you just paint a 55 Eldo Artisan Ochre and wala !!....close enough !!
This one came in with an Elvis pink body and black and pink leather interior! yuck !
I dyed the interior all black, primered the body and then paint....
The pink body was awful....it looked like the trunk was filled with Mary K cosmetics....
This one is probably the best running car I have....I really should wash and wax her but it's too much fun driving her around....
Baillargeon
#15848
Needed an new fuel sending unit. The OEM part was way off. It would read 1/4 at dead empty. Not good!
All done. The gauge works as designed. New sending unit, sealing O-ring and locking ring and new rubber lines and clamps. When in the dry tank, the gauge sits at a perfect empty. Added 7 gallons of fuel and it's a perfect 1/4. 28 gallons total. Still need to go to the local stop-N-rob and add fuel 7 gallons at a time to see the gauges accuracy.
Still no low fuel light, so I'm assuming a small bulb. I can't find anything about it in the FSM bulb chart. But, running a fuel tank under 1/4 is just sheer stupidity.
Replaced the driver's side CV axle today.
A lot easier the second time around.
But there was an issue with the length of the OEM attaching screws/bolts. They would bind up with just one small section of flange.
The original axle to output shaft bolts are too long with the thinner inner joint housing flange, so I needed to either grind the bolts shorter or just shim it with one simple washer. I head to the stock boxes and pull out 6 identical washers. I can slip a .020 feeler gauge between the trans case and the screws. Even torqued back to 70 pdft.
New sneakers being installed on Monday morning. I'm just about ready to travel.
The flanges are thinner on the new production assemblies.  Its not a problem on the passenger side since that is on the extension shaft and there is nothing close by for them to hit.  Drivers side as you noted it will hit part of the housing casting.  The other issue unless they have corrected it was the holes are much larger than the original so the original bolts and washers barely have anything to grab on.
Today (and the whole summer) I'm really happy that I finally got all the bugs worked out and my rig is happy to run 'regular' gas.  The non Ethanol stuff is more than a dollar more per gallon, not a big deal for the lawn mower but adds up faster at 20+ gallons per fill up.
But it will save you that much just in the damage deathanol will do to your car.
Quote from: Big Fins on September 06, 2024, 11:26:42 AMBut it will save you that much just in the damage deathanol will do to your car.
I'm not expecting any damage, one reason is I'm going through it at a reasonable rate, about 2 tanks per month.  I do still plan to fill up with the non ethanol stuff when it comes up on winter storage time.  EFI also makes a difference, no vapor lock fuel boiling out of the carb issues.
