What have you done with your Cadillac today?
Started by TJ Hopland, May 07, 2020, 01:57:50 PM
What's along the other wall?  Cars we are not allowed to post pics of here?   Where is the work area?
Look at all that space that could be packed with more stuff. Or am I the only one thinking that?   I would have shelves along the back probably with the intention of some sort of nice display but I'm sure that wouldn't last and before long they would be packed solid with something.
That's the showroom. The shop is out back where no one can see the newest projects.
jaxops
Drove the '56 around the block and adjusted the timing a bit. It was 72 degrees yesterday!
1979 Lincoln Continental
jaxops
Pulled the 1956 Rochester 4bbl carburetor and sent it out for remanufacturing.  It's been rebuilt numerous times and the car still bogs down accelerating from idle.  So we'll see how this does coming back like a new carburetor.  I sent it to Carburetor USA in Blackwood, NJ.
dogbergs
There is oil and there is pressure!
-51 Cadillac serie 62 convertible, project
-64 Dodge Polara 2dHt, 1 driving and 1 for spares.
-70 Volvo 121 (Now sold after 21 years)
-63 Plymouth Max Wedge clone, project
-42 Harley WLA
-43 Royal Enfield WDCO
-33 Ford Pick up, project
jaxops
Just got the 56 Cadillac carburetor back from CARBS USA in Blackwood, NJ.  All redone and anodized.  Can't wait to get it on the car.
Jim Miller
I finished changing the water pump on my '41, replaced hoses, belts, and clamps with period correct. Then cleaned the ends of the grounds. A short time back I changed the oil, greased all 19 fittings, added some Penrite to the steering box, checked other fluids.  Ready for spring. Starting the 49 next.
Jim Miller
1941 6219
1949 6237X
1957 62 Sedan
1970 CDV
2025 XT6
Past:
1991 SDV
1999 DeElegence
2006 DTS
2013 XTS
2016 SRX
2021 XT6
Cadillac Jack 82
Showed Shelley that not all progress is good progress...
CLC Member #30850
1934 Harley VD 74ci "Rosie"
1948 Buick 76S "Lillian"
1950 Cadillac CDV "Doris"
1959 Cadillac CDV "Shelley"
Past Cars
1937 LaSalle Coupe
1955 Cadillac CDV
1957 Cadillac Series 62 Coupe
1964 Cadillac SDV
and a bunch of others...
Cadman-iac
Quote from: Cadillac Jack 82 on January 31, 2025, 02:51:57 PMShowed Shelley that not all progress is good progress...
 What the heck is that in front of you? Looks like a painted box with lights. Fugly!!
 Rick
CLC# 32373
Cadillac Jack 82
CLC Member #30850
Past Cars
1937 LaSalle Coupe
1955 Cadillac CDV
1964 Cadillac SDV
jaxops
My son-in-Law and I got the carburetor back together and onto the '56 yesterday.  It started right up.  Nice to have the car running so smoothly and a quick startup.  CARBS USA did a great job and I recommend them to you.  It was a nice tribute after returning yesterday from the funeral of Bruce Warren of Bruce Warren Auto Repair in Norfolk Bruce Warren.  He was inspiring us from above!
jwwseville60
Well, where do I begin?
1965 FW 60. Owned by an FBI agent in the early 1970s.
Lots of bad wiring needed fixing. So unusual!
All 4 vent windows work now. (FBI-approved pistol ports).
New wheel bearings and brake pads. Pulls gently to the left when stomping on them from 100 mph.
Glove box will open...but wont shut yet. Replace with steel gun safe?
Interior lights work now....for some odd reason.
New Diamondback WW shoes. Gotta handle those high speed corners.
New single factory exhaust...quiet for stakeouts.
Bullet hole fixed and painted.
Lifetime CLC
Sounds like that was almost a full size James Bond car.
Cadillac Jack 82
Doris tucked in for the long road to AZ to meet her sisters.
CLC Member #30850
Past Cars
1937 LaSalle Coupe
1955 Cadillac CDV
1964 Cadillac SDV
Carfreak
Quote from: jwwseville60 on February 08, 2025, 08:31:01 AMGlove box will open...but wont shut yet. Replace with steel gun safe?
GM had a glove box problem for many years. Frustrating as it should have been a simple thing to figure out but happened across the various makes.
Was the bullet hold going into the car or coming out of it?  We had a 1j971 Vista Cruiser with a bullet hole going up through the roof from the passenger front seat. It was a winter car (with W-30 455) and didn't leak so we left it as-is. Former owner indicated he was cleaning his gun when it happened.  Un huh...
Moody
Building a patch panel for the front fender skirt area of the quarter panel.This is two pieces welded together. The long part of the wheel opening gets welded to this, then the whole mess will be welded to the car.
Moody
jwwseville60
Bullet hole was in the trunk right side going in.
Lifetime CLC
Cadillac Jack 82
Was finally able to get a collage of the 50s coupes in one photo.  1950-1959.  Its neat to see the subtle and dramatic changes from a mere 10 years.  Now I can't tell the difference between at Cadillac Escalade and a Chevy Tahoe.  Time to up the ante there Cadillac.  Get back to your roots.
CLC Member #30850
Past Cars
1937 LaSalle Coupe
1955 Cadillac CDV
1964 Cadillac SDV
Lexi
Quote from: Cadillac Jack 82 on February 18, 2025, 10:42:56 AMWas finally able to get a collage of the 50s coupes in one photo.  1950-1959.  Its neat to see the subtle and dramatic changes from a mere 10 years.  Now I can't tell the difference between at Cadillac Escalade and a Chevy Tahoe.  Time to up the ante there Cadillac.  Get back to your roots.
Agreed. Modern vehicles are so nondescript. I think it is the Tesla that has a distinctive front as no grille, but most cars bascially look the same from about 20 feet out. That is why even if I had money, I would probably not buy a new Cadillac. In the old days they were a statement recognized by other users of the road when they saw a Cadillac, even if parked. Like, who wants a status symbol if it is not immediately recognizable? That is a no brainer. So yes, "up the ante" and "get back to your roots" Cadillac, as Tim said. Clay/Lexi
