AC compressor on 1967 DeVille
Started by jims427400, June 25, 2020, 03:42:10 PM
jims427400
Car has 30,000 miles and the belt has been removed for many years. I don't want to remove hoses because I'd like to keep freon if possible. I'd like to put belt on and see what happens but I don't know what I might be ruining. I've read that I can remove/ replace the clutch if that is the problem. Can someone tell me what I can expect when I hook this up and what is the worst case to expect?
Also how hard is it to diagnose and replace clutch if that is the problem?
I believe it is the original compressor BTW
Thanks all,
Jim
jims427400
Jim,
The first quest I would ask is, is there pressure in the system now?
To see if the compressor is free you can rotate the center hub.  There must be some reason the belt was removed and a locked compressor or bad clutch plate are the most common.
Daryl Chesterman
It is also possible that the clutch bearing is bad and can be checked by removing the belt and see if the end plate turns easily and smoothly.  By applying battery power to the clutch, you can see if the clutch will engage.  If it does, you can see if the compressor will turn over by hand.  When you apply power to the clutch, you should be able to hear a good, solid "clunk" when the clutch engages.  The clutch and bearing can be replaced without losing any Freon.  You need to have the special tools shown in the factory service manual to remove the clutch.  They are probably readily available on Ebay
Daryl Chesterman
Dan LeBlanc
Last time I replaced an A6 clutch, I was able to get the tool kit from O'Reilly's across the border - pay a deposit, take it home, do your work, bring it back, get your deposit back.
Dan LeBlanc
The first time I had to do it I made my own tool to perform the task.
An old bolt of the correct thread, a longer, thinner bolt, a Lathe and drill and tap, and finished.
jims427400
Thank you all, sorry for not getting back right away. Daughter got married. I removed the belt about 10 plus years ago but have to be honest I don't remember why. I remember someone at the time also said I had a problem with that vacuum switch thats mounted on the passenger side fire wall(yellow and orange wires,black/purple tubes) that works with the temp control inside the car.
I'm pretty sure it still has freon in it.
I'm going to put the belt back on and fire it up and guess we'll see what happens.
jims427400
So I checked and the end of the compressor turns but it is not easy. I assume it's the clutch, just in from the end, spins easily. What does that mean?
Also how can I temporarily hook up 12volts to check if clutch works?
Thanks all
James,
One lead on the clutch is the ground and the other is for a 12Volt signal.  You did not answer as to whether the system is still under pressure.
jims427400
I'm only assuming it is. How can I tell you for sure?
The correct way is to put a set of refrigeration gages on the system and read the pressure. Just depressing the schrader valve on one of the service fittings and listening for the “pfffsssst”’is a poor substitute since it is kind of hard to translate the”pfffsssstt” into psi.
chrisntam
Quote from: "Cadillac Kid"  Greg Surfas 15364 on June 29, 2020, 05:15:57 PM
Everyone knows more f's and s's mean more pressure...
;D
1970 Deville Convertible
Dallas, Texas
jims427400
I'll see if I can barrow a set of gauges and get back.
What about power steering - is it on same belt?
Not on a 67 Scott. That’s a 429 motor.
