1974 ELDORADO OEM DUAL PORT ALC REAR AIR SHOCKS
Started by THEbeSTPLACE007, July 13, 2020, 01:26:45 AM
THEbeSTPLACE007
I'M IN SEARCH FOR A PAIR OF REAR OEM ALC AIR SHOCKS. ONE SHOCKS COME'S WITH ONE INTAKE PORT AND THE OTHER HAS TWO AIR PORTS. ANYONE WHERE I CAN FIND A PAIR OF THE OEM SHOCKS.\
THANK YOU
Mike Josephic CLC #3877
Sorry to tell you that you will have a very difficult
time to find the OEM replacement shocks for your
car. They have been unavailable for about 20 years
now.
Most people, in order to replace the rear air ride
system purchase a retrofit  air shock with a port
near the license plate frame where they can add air.
They are made by several firms.
Does your original vacuum compressor still work?
If not, that's your only option since the parts for
the compressor are no longer available.  They are
not being reproduced.  Sorry for the bad news.
Good luck,
1955 Cadillac Eldorado
1973 Cadillac Eldorado
1995 Cadillac Seville
2004 Escalade
2011 Buick Lucerne CX
CLCMRC Museum Benefactor #38
If the original compressor still works you will need to change the hose from the valve at the rear axle to have a T and use replacement shocks with single ports.
