1957 1958 Convertible Rear Tacking Stick
Started by lancemb, August 04, 2020, 01:53:18 PM
lancemb
Please PM me with any available, or leads.  Thanks!  Should look like attachment.
Quentin Hall
You can use polyethylene strip available label from most plastic supply companies. Heat it with a heat gun to bend into shape.
53 Eldo #319
53 Eldo #412.
53 Eldo #433
57 Biarritz
53 series 62 conv
39 Sixty Special Custom
57 Biarritz
Mike Baillargeon #15848
Quentin's idea will work......or you can give Hydro-Electric a call....they will copy your old one or they may have one on the shelf.....
https://www.hydroe.com/
Baillargeon
#15848
lancemb
Quote from: Quentin Hall on August 07, 2020, 09:22:39 AM
Thanks for the suggestion.  What thickness would you recommend?
