Vacuum Manifold needed
Started by Steve W, April 23, 2023, 07:02:45 AM
Steve W
My car is a 68 Coupe deVille. This part attaches to the firewall and got very brittle, the little fittings just snap off! I need a replacement please!EBCF1E31-C2B7-4A61-B8DF-C40B659C6637.jpeg
Steve Waddington
1968 Coupe deVille
North Hollywood, CA
CLC Member # 32866
Cape Cod Fleetwood
Unobtanium. You'll have better luck getting a copy of the Dead Sea Scrolls. If you find the part used
it will be just as brittle, IF you found one NOS you'll need a HELOC on your home to buy it. Reach out to
John Abend on the Collective, he may have a work-around using a manifold from NAPA etc.
The Past -
1996 Deville Concours
1981 Coupe De Ville (8-6-4)
1976 Sedan De Ville
1975 Sedan De Ville
Steve W
Quote from: Cape Cod Fleetwood on April 23, 2023, 09:42:11 AMUnobtanium. You'll have better luck getting a copy of the Dead Sea Scrolls. If you find the part used
John Abend on the Collective???
Steve Waddington
1968 Coupe deVille
North Hollywood, CA
CLC Member # 32866
Cape Cod Fleetwood
The Past -
1976 Sedan De Ville
1975 Sedan De Ville
Steve W
Found one. NOS. Expensive, but works like it should! Happy to have the correct part!
Steve Waddington
1968 Coupe deVille
North Hollywood, CA
CLC Member # 32866
