Shift Shaft Pin Removal 1975 Eldorado Turbo 425
Started by P. Manoogian, April 30, 2023, 06:39:45 PM
P. Manoogian
Hi folks, I have heard horror stories about getting this pin out to remove the shaft so I can replace the seal on the shifter shaft. I cannot understand why the manual says to "bend it" when it so clearly appears to remove straight down. Am I overlooking something? If you have removed this pin with success please share how you did it. I do NOT want to break it in the case. Thanks!341931862_606646754725771_6244568738934816231_n.jpg
1961 Eldorado - Shell Pearl/Mauve
1962 Corvette 327 - 250 HP Automatic Triple Black
1963 Impala SS Convertible - 283 Automatic Black Red Gut White Top
1965 Impala SS Coupe  - 502 Turbo 400 - Crocus Yellow
1974 Corvette L84 4spd Coupe - White / Black Leather
P. Manoogian
I got this out. I will leave this thread up so if in the future someone needs help on the same issue they can contact me,
scottsdaleaz
I need to do mine too soon.  Did you find a way to pull it straight out?
1975 Eldorado
Member Number: 34629
IcebearLars
Mine broke off - feel pretty screwed right now. Any ideas how to remove that? It broke so close off to the Alu case that I can't grab it any more - what a shit piece of engineering!
