1959 Cadillac Suspension Washer
Started by MIKIMBIN1, July 20, 2023, 05:12:07 PM
MIKIMBIN1
Hi I need this washer is for the front suspension between Coil Spring and frame
has 5 3/8" Outside by 4" inside
Vic Fdez
Vic@59Caddy.me
305.525.9292
Cadman-iac
  If the 60 models are built similar to the 56's, you only need one of those, it goes on top of the right front spring to compensate for the weight of the air conditioning.
Rick
CLC# 32373
MIKIMBIN1
OMG thanks a lot, yes my has only one in the right side.
Thanks a lot
Vic Fdez
Vic@59Caddy.me
305.525.9292
Cadman-iac
Quote from: MIKIMBIN1 on July 20, 2023, 07:02:57 PMOMG thanks a lot, yes my has only one in the right side.
Thanks a lot
 No problem, glad to help.  It took me a while to figure out why I only had one of those too.
CLC# 32373
