1969 Cadillac DeVille Project
Started by R Simone, August 07, 2023, 08:41:12 PM
With the rocker arm tips so worn, I would be looking at having them refaced if possible, but the depth of wear might be too deep requiring re-hardening of the arms.
What type of oil has been used in the engine?   If it is modern stuff, with no Zinc, then you will definitely find that the Cam lobes and Lifters are worn out.
The lifters can be restored by re-radius grinding them, which is far better than purchasing new ones which most likely be Chinese made.
A friend thought he was using good oil in his two cars (Hot Rods) and thought the term "for Modern Engines" on the container meant for engines that were newer than the cars they were in.   Couldn't get proper tuning on both, and it turned out that the Lifters were shot (badly worn) from using this new oil.   No Zinc is really bad in a non-roller cam engine.
R Simone
#21
Hard telling what oil was used for the first 50 years lol, but it was rarely driven the last 20 years - I used higher zinc oil but have only changed oil once or twice since owning/driving part of one summer. My local machine shop rebuilding the engine is the gold standard in these parts (been around since the 60's), but they don't dyno. You take them the engine minus carb and distributor and they clean, machine, assemble.
I am having them weld nuts to the inside of the timing cover for the small water pump bolts - they weren't stripped yet, but they were close.
The cam had some minor wear so it will get some regrinding, but they said everything else looked pretty good. I think there's just a bit of uncertainty for them on the rockers because it's not a super common engine and they're non-adjustable. They agree with the comments I see all over the forum about using original when you can because a lot of the new stuff is junk.  They are checking a source that might have quality ones and will let me know this week. I think they just don't want to see me spend several grand on a rebuild and have something small fail and ruin the engine. I don't mind spending the extra, but also didn't want to get junk. We'll see what they find.
James Landi
Your hydraulic lifters take up a good deal of wear in the valve train, (are you having a valve springs replaced?) In my judgement, having a reasonable expectation regarding just how you want your half century car to operate when it comes out of the shop seems to me to be a good starting point. Needless to say, a perfectly rebuilt engine with all of the torque and horsepower as when new has the potential to shorten the life or destroy the rest of an ageing  drive train... also, what is the status of the radiator... I had the unfortunate experience several decades ago, of rebuilding a Cadillac engine, and shortly thereafter, blowing out the head gasket on route 95 in Fl, because the original radiator was partially clogged.  I mention these concerns to you respectfully,   James
R Simone
Thanks James.  That's one of the questions they've asked me to consider while they're working out the parts list. "How are you going to use the car; will it be Sunday drives and date nights, or something your going to romp on and drive thousands of miles a year?"  (For me it's date nights, cruising, and occasional trips to the lake an hour away). I thankfully did have the radiator & condenser rebuilt already and it was a good thing. The radiator "looked" decent, but was clogged pretty good and had a tiny leak I hadn't seen.  I also sent the carb out to Bowen's in Bristol, PA and man that thing looks fantastic!  (Will post pics when I unbox it again)
I'm going to contact them today and see what they've found if anything on the rockers and will ask about the valve springs - still working on a final parts list.
R Simone
I've been waiting for a warm day to spruce up the engine bay and today it got up over 60 degrees here in NE Indiana so we could open the garage door (fumes), but it was windy so we didn't push her out. Just freshened things up with Krylon Satin and will apply another coat when we can get it out under the sunlight. We moved it out of my friends shop and pushed into his "house garage" while awaiting machine shop to finish so no real work going on right now, mostly a waiting game. Ordering some AC components and odds and ends...
R Simone
My engine is supposed to be completed this week and I dropped off my powder coated parts for installation. They do look a little lighter in the picture than in person. It's been just over 4 months that they've had the engine and it's getting nicer in NE Indiana so I'm ready to get her back together and hopefully work on the less pressing projects that need done here and there.
R Simone
Pics didn't attach first time...
R Simone
They finally completed my engine after 4 months and I picked it up this past Friday. I was in a bit of a rush just to get it dropped off at my friends shop and I didn't think to take more pics because now my head is spinning thinking about all the misc. stuff that will now rear its head. The Machine shop pics are in a weird format but at least wanted to get one pic posted for now.  Now over to the Technical Forum for searching/questions! lol
R Simone
Well schedules and stars finally aligned and we made some progress last week and were able to drop the engine into place. The older I get it seems my nerves aren't what they used to be and dangling several hundred pounds of metal around over the Cadillac made me jumpy for the duration. The victory was short lived however as when we went to tighten things up today to move forward (torque converter & bellhousing bolts) something was off.  We fought it about four hours and accomplished almost nothing except getting the torque converter bolts in and decided to surrender for the day. The car is jacked up pretty high in front to accommodate our "physiques" and despite jacking up the trans, taking weight on and off of the engine, and just letting everything rest, as soon as we got all of the bellhousing bolts close to tight the engine wouldn't turn over - back them out a bit and the engine turns over just fine. We don't know what could be hanging things up..?  I'm going to post in the technical help forum because we're both at a loss and any help or suggestions appreciated. Feeling pretty deflated after today.
mario
Flexplate on backwards? Converter not seated all the way?
Good luck
Ciao,
Mario Caimotto
R Simone
We had moved the car around quite a bit and neglected to check that the torque convertor was seated completely.  I hated to do it, but we pulled the trans and had everything checked out "just in case", replaced the pump gear and re-sealed.  The plan is for take 2 on the install this Friday...
At least I know it's all good now and also got to give her a fresh spray of the correct paint.
When fitting the Trans, I always make sure that the Torque Converter can move forwards and backwards a small amount before completely tightening up the bellhousing bolts.
If after this, the Torque Converter is tight, then it is not seated.   There has to be some movement between the TQ and Flex Plate, and when the TQ nuts are tightened, you are actually pulling the Flex Plate slightly rearwards.   This assists in aligning the Ring Gear as well.
R Simone
With the torque convertor in place the trans slid into place like butter... Everything's buttoned up underneath and the car is back on the ground, starting to bolt things on the engine and looking at pictures to remind me of where some of that stuff went! lol
R Simone
The car is back down on the ground (with the engine much easier to reach!) and we're starting to bolt on all the pieces including mostly new AC components. I had Bowen's rebuild the carb over the winter and it looks like new!  During reassembly I'm also realizing some misc. brackets and parts that I should have cleaned and painted. Luckily my friend has talked me into slowing down and taking care of them now so I don't regret it. Today I cleaned and painted the air pump bracket, pulley, etc. Probably not many hours from having it running, but we usually only get a few hours here and a few hours there instead of long stretches of time.
R Simone
It's been many months of downtime since pulling the engine and starting this project, but looking through some pictures recently I was reminded that she has come a long way and the "before and after" are always satisfying.  There are some wires and all of the vacuum hoses to run, some routing and clipping, oil priming etc., but I think a few more work days and we'll be ready to try and start her up!
Cadman-iac
  Definitely looking much better now. I wish mine had looked that good when I owned it.
 Great job, if it runs half as good as it looks it'll be great.
 Rick
CLC# 32373
R Simone
So after a two week vacation away, some other scheduling delays, and a stubborn distributor we FINALLY got to fire her up last night (Still haven't decided on a name yet...).  TDC, Engine fully primed with break in oil, fuel system primed.  I was nervous about following the flat tappet cam break-in process after seeing all kinds of horror stories online - I literally had butterflies in my stomach. However, it actually fired right up and I began the process of varying the RPM ~1500-3000. I'd never done this before and all the things baking in made me nervous.
Me from inside the car: "What's smoking?"
Buddy: "Everything"  :D
However, part way through the process she got hot and coolant started leaking from a few spots. Apparently my shiny new black spring clamps just weren't holding and/or I picked the wrong sizes. At first I thought it was my new heater core leaking and that about gave me a nervous breakdown at the thought of tearing all that apart again, but it was just the way the coolant was dripping. After shut down it got hotter with the cap making some noise, steam, etc.
We went for new worm clamps and tried again after she cooled down. The leaks were fixed, but part way through again she got hot and the radiator cap made some awful noises, steam, & overflow boiling after I shut it down.
Prior to the start we had filled the block with coolant with the t-stat out, then the radiator, burped the upper hose etc. Radiator re-cored, new heater core, new water pump, new hoses, new fail-open T-stat. It was pretty late so we called it a night and we probably had ~15 min of break-in time so far which wasn't ideal, but we couldn't keep going as hot as it was.
Thoughts are likely/hopefully it's timing, but it's tricky because you have to set timing at idle, but my understanding is that you CANNOT let it idle during the break-in process. I've read people often use external fans and spraying the radiator with a hose occasionally to keep it cool during the break-in and THEN idle/set the timing so thinking about trying that to complete the process.
I expected some leaks etc. but not the overheat. In addition my blower motor isn't working all of the sudden (I tried turning the heater on during this and got nothing)
James Landi
I suggest that you purchase a GOOD infrared thermometer so you can diagnose for potential hot spots on the engine... especially the cylinder heads, intake and exhaust manifolds... regarding hoses,clamps, etc. I've had experience with leaks caused by painted attachment surfaces.  I've learned not to assume that a hose tightened to a painted steel coolant pipe will necessarily hold pressure. Hope this helps,  James
R Simone
My friend actually has one, but the batteries were dead, but we'll have it at the ready next round.
Quote from: R Simone on June 26, 2024, 09:33:26 AMSo after a two week vacation away, some other scheduling delays, and a stubborn distributor we FINALLY got to fire her up last night (Still haven't decided on a name yet...).  TDC, Engine fully primed with break in oil, fuel system primed.  I was nervous about following the flat tappet cam break-in process after seeing all kinds of horror stories online - I literally had butterflies in my stomach. However, it actually fired right up and I began the process of varying the RPM ~1500-3000. I'd never done this before and all the things baking in made me nervous.
Congratulations on getting it started, but I seriously question the varying the revs from 1500 to 3000, as this is definitely not correct.
Go straight to 2,500, and stay there till you have to turn it off because of other reasons, and when turning off, don't let it idle back, just hit the switch.   Correct what you have to, then start again.   No need to go more than 1/2 hour in total, and don't worry about the rings not seating, as this has to be done on the open road, with little or no traffic around.
You NEED the constant speed to enable the cam and Lifter bases proper lubrication, and 1500 is just not sufficient.   Plus, 3000 is too high.
Plus, if you are inside a garage, I always make sure the car is 99% out the garage door, so you aren't killing yourself with fumes.
