Rear Main Seal Neoprene 1938
Started by KurtS, August 16, 2023, 01:42:43 PM
KurtS
I need to replace the rear main seal on my 1938 Series 75. The replacement seals, Best 5117 or Mercedes 001 997 1241, are rope seals. They are very difficult to fit in without removing the crankshaft.
Does anyone know if there are Neoprene seals that would fit and were they are available?
Kurt Schellenberg, CLC 20401
toybox
As far as I've found the best is the Mercedes because its graphite impregnated. That what I ended up putting in my 46 . Tim
Ask Terrill Machine. He is a part's seller and is providing such seals. Or go to the Best Gasket site.
KurtS
Thanks, Roger. Terril and Best have rope seals, but I'm looking for neoprene seals. since these are much easier to slip in.
My mechanic and I did the job once with a Best rope seal, and it was really not something you want to do often.
Jay Friedman
Quote from: KurtS on August 18, 2023, 08:43:37 PMThanks, Roger. Terril and Best have rope seals, but I'm looking for neoprene seals. since these are much easier to slip in.
Roger is right.  Terrill sells neoprene seals.
1949 Cadillac 6107 Club Coupe
Decatur, Georgia
CLC # 3210, since 1984
While searching through the on-line parts catalog, I saw that the neoprene seals are not available for your car.
