1955 Eldorado Dashpad to Frame Mounting Spacers
Started by Lockhouse, August 23, 2023, 09:31:57 AM
Lockhouse
Hi,
On my '55 Eldorado the rubber dashpad mounting grommets that the bolts go through to secure to the front window inside rail have perished and I'd like to replace them. I counted six I think, in various stages of decay. None are any good, some are missing entirely. Are they part #4614412?
Also, when I took the dashpad out I found the attached metal spacers. There were only two present and they were different sizes. Assuming they belong there do the grommets fit them? If so are they all supposed to be one size and can I get replacements?
Lastly - any idea what is part number #4630149 on the attached parts list?
Grateful for any assistance.
Best regards,
Andy
Caddy Wizard
There should be 6 oval grommets on your 55, with 6 identical-sized spacers.  The fact that you only have two and they are not the same, tells me that someone took the dash off in the past and lost all or most of the spacers.
By the way, the spacer on the right in the photo looks incorrect to my eye.  The one on the left looks like the correct style.
Part number -0149 is the grommet for your dash, I believe.  There should be six of them.
Steele Rubber sells the grommets.
Art Gardner
Lockhouse
Hi Art,
Thanks for the info. I thought the one on the right looked wrong too.
Is https://www.steelerubber.com/instrument-panel-grommet-70-1654-88 the correct rubber?
I can't find a link for the metal insert - do Steele sell them also?
Best regards,
Andy
Lexi
Thought I had some spare metal spacers but don't see them in my list. Will have to have a physical look. Clay/Lexi
Caddy Wizard
Quote from: Lockhouse on August 24, 2023, 05:34:17 PMHi Art,
Best regards,
Andy
That Steele Rubber part number looks like the correct part for your car.  You should need 6 of them.  I don't think anyone makes the spacer as a new item.  But not hard to find from parts cars...
Art Gardner
Lexi
Best regards,
Andy
I don't think those metal spacer/grommets are reproduced. I checked my hardware and I did find some. I believe they came off of a '56 CDV, and I believe they are the same for 1955. Can sell you what you need if interested. Can post a picture to be sure as well. Clay/Lexi
Lexi
PM sent with pics to follow. Clay/Lexi
Lockhouse
#7
Thanks Clay;
OK; I measured both types that I have with a micrometer; all dimensions in millimetres for accuracy.
"Low" Type; No.0150
28.4 x 20.55 overall
18.6 x 10.75 raised section
7mm overall height
2mm flange
5mm proud
"High" Type; No.8316
27.88 x 22.50 overall
17.8 x 12.15 raised section
9.75mm overall height
2mm flange
7.75mm proud
I'm assuming one is pre-56 and the other is post-56 as per the MPL photo above. Steele lists the rubbers with external dimensions 33.3mm X 27mm (1"5/16 x 1"1/16) which as expected is slightly larger than both. They also list the part as good for 1953 to 1975(!) so I suspect it may be a generic part that you just push to fit. I have mailed Steele and asked them for height and internal dimensions which they don't list - just to check as it's over $100 for 6 mailed to the UK.
The part numbers themselves (0150 and 8316) on the flanges don't match the MPL numbers of 463 0149 and 467 1848.
Best regards,
Andy
Lexi
Quote from: Lockhouse on August 28, 2023, 06:27:52 AMThanks Clay;
"Low" Type; No.0150
7mm overall height
2mm flange
5mm proud
2mm flange
7.75mm proud
Best regards,
Andy
Hello Andy. Attached are some images of what I have here. Image #1 shows 6 of the low profile metal spacers compared to 3 of the "Tallboys". The photo shows how they sit higer than the the low profile ones as they overlap them. The next images show my micrometer measurements of the "height" of each one @ 7.05mm and 9.69mm respectively. Very close to the 7mm and 9.75mm sizes you obtained. Clay/Lexi
Lockhouse
#9
Just heard back from Steele Rubber.
The grommets are 1/4 inch deep and the internal hole measures 11/16 by 7/16.
In mm that's 6.35 deep and internally 17.4625 x 11.1125.
I think I would tend to fit that to the shallower ones so there was some rubber overlap and I would expect to be able to stretch them to fit length x width (18.6 x 10.75).
OPG sell the Steele parts cheaper than Steele.
Bob Kielar
Did you try Rubber the right way? They are Steele products and I found in some instances they cost less then Steele.
Bob
Keep Cruzin
1955 Cadillac Fleetwood
Lockhouse
Hi Clay,
I finally had an excuse to take the dashpad out - all fitted perfectly - thanks again for your help. Photos attached if anyone needs them for future reference.
Andy
Lexi
Yey! I was wondering how my parts fit. That looks great. Thanks for the update. Clay/Lexi
