1941 Under Hood Insulation
Started by J. Russo, September 14, 2023, 09:08:15 AM
J. Russo
I'm considering installing insulation under the hood of my 1941 Series 63. I have a product called Dynaliner from Dynamat that I have left over from insulating the floor.
My hood gets pretty hot and has no insulation. I haven't found in the judging or authenticity manuals if insulation was ever installed in these models.
Does anyone know if adding insulation under the hood is an issue with judging where it would result in a deduction of points?
Thanks in advance.
John Russo
CLC Member #32828
Paul Tesone
Can't answer the judging question , but I'm wondering if hood insulation would hinder dissipation of heat from the engine bay and contribute to "heat soak " - something so often experienced in the pre war Caddys . Paul Tesone CLC #6876 .
Jeff Hansen
John,
To my knowledge, there was never any insulation on the underside of the hood, the inner fenders, or the engine side of the firewall in 1941.  You don't see it mentioned in the authenticity or judging manuals because it was never installed at the factory.  There was a type of insulation installed on the interior side of the firewall to keep heat out of the passenger compartment.
Adding insulation under the hood might help with your heat issue on the hood, but Paul has a good point about heat dissipation - you don't want to hold engine heat in on these cars.
A few other things to consider:
  • Since you asked, there would be appropriate deductions for such insulation in CLC judging for authenticity
  • If you insulate the underside of the hood, depending on what you use, that could possibly add additional weight that the hood springs may not be able to handle
My two cents anyway.
HTH,
Jeff
Jeff Hansen
1941 6019S Sixty Special
1942 7533 Imperial Sedan
harry s
Like Jeff I'm not aware of any factory under hood insulation on '41s. I have seen some with undercoating to include my '41 67 Series and '48 conv. I'm guessing this would have been done at the dealer along with chassis undercoating.    Harry
Harry Scott 4195
1941 6733
1948 6267X
2011 DTS Platinum
J. Russo
Thank you for the input and expressing your concerns. I'll hold off from doing this.
John Russo
CLC Member #32828
LaSalle5019
Hood insulation was only added to reduce engine noise. Both the previous points about holding in heat and not enough spring are good ones.
Whit Otis, 1188
#6
The 1940 Custom 60 Special LP Fisher car had undercoating on the bottom side of the hood.  This car was presented as all original, however a number of items were not.  That said, I personally examined this car on two occasions and I would say that the undercoating did look to be original given the look of it and the careful application of it.  Attaching picture with a partial view of the underside of hood.  Since this was a one off custom with chopped top, leather padded roof, extended chassis, etc., I would guess it unlikely a dealer would have done the undercoating since it was probably delivered from Fleetwood directly to LP Fisher.
Whit Otis
Whit Otis -
1941 6219D Custom
1941 6219D
1940 7533F
1986 Mercedes Benz 560 SEL
1999 Bentley Arnage
2019 XT5
Drawing of AP Sloan Custom by Terry Wenger
jwwseville60
There are a number of high heat reflective aerospace materials out there.
We used one for my 63, but it was all custom so originality was never there.
If I hear you right, yours was custom as well.
I believe you can paint this material too.
My 1947 flathead v8 runs hot as designed.
I would worry about reflecting heat back down onto it.
Lifetime CLC
