1966 Deville Convertible BULB
Started by RandyK, October 08, 2023, 12:53:06 PM
RandyK
Where can I get this type of Bulb.  It is the interior light on the underside of the dashboard on both sides. I would prefer to find an original one.
RandyK
Daryl Chesterman
Does the bulb have a number on it?  If it doesn't have a number on it, look in your owner's manual to see what number it specifies for courtesy lamps (or whatever Cadillac calls the under-dash bulbs , then you can look online to see if you can find one, or a good substitution.  As a substitution, you could look at a NAPA # 6451-N bulb to see if the dimensions and wattage are the same.  Be careful of using a bulb that has more wattage than the OEM bulb, as a higher wattage will give off more heat and be bad for any lens that may cover it (if there is a lens).
Daryl Chesterman
gkhashem
#2
Go to Sylvania website
https://www.sylvania-automotive.com/on/demandware.store/Sites-sylvaniaautomotive-Site/en_US/BulbFinder-Show?carId=4730&oepn=90%7C212-2&notes=Compare+To+Original
Looks like a #212 bulb
This is for a courtesy light bulb.  Check the service manual also. Shape looks different but if wattage and size fits who cares its under the lens.
1970 GMC C1500
1992 Oldsmobile 98 (OCA 1st)
1996 Oldsmobile 98
Past Cadillacs
1959 Coupe Deville
1966 Coupe Deville (Sr #861)*
RandyK
RandyK
