Need help replacing horn wire on 1955 Series 62
Started by Kevin Kenneally, October 11, 2023, 01:46:34 PM
Kevin Kenneally
Has anyone replaced the horn wire on a 1955 Caddilac?  My horn will start going off when the wheel is turned and will stop as I continue to turn the wheel.  Sounds like a short in the wire.  The car only has 22,000 original miles!  I have everything apart on the steering wheel but my question is at the bottom of the steering column the wire goes up at 90 degrees..  I have attached a picture..  what is inside the 90 degree post off the column??  just trying to understand what I'm dealing with before I take it all apart!!  Unfortunately the wire doesn't just come out of the bottom of the column, this 90 degree move makes me wonder what is in there for it to be wired like that??  Appreciate any help!!
Cadillac Jack 82
Theres a brass sleeve in the steering column that splits over time.  The only way to fix it is to remove the whole steering column and replace it with a new one.  I had a similar problem in my 1954 Buick but I was able to get to the brass fitting through the connection port and use a punch/hammer to fix it.
CLC Member #30850
1934 Harley VD 74ci "Rosie"
1948 Buick 76S "Lillian"
1950 Cadillac CDV "Doris"
1959 Cadillac CDV "Shelley"
Past Cars
1937 LaSalle Coupe
1955 Cadillac CDV
1957 Cadillac Series 62 Coupe
1964 Cadillac SDV
and a bunch of others...
Kevin Kenneally
Are thos brass sleeves available and if so from where??
Cadillac Jack 82
I'm not sure anyone reproduces them.  What you can do is buy the correct size brass fitting at a hardware store and fit to the assembly as needed.  If you're luck you might be able to do the repair to the sleeve as I mentioned in my original post.
CLC Member #30850
Past Cars
1937 LaSalle Coupe
1955 Cadillac CDV
1964 Cadillac SDV
Saturnin15
The brass sleeve on my 56 was worn out.  I brought it to a machine shop and the guy was able to make a new one.  Hard to do because it is very thin but doable.
Sedan Deville 1956
Lexi
Quote from: Kevin Kenneally on October 11, 2023, 01:46:34 PMHas anyone replaced the horn wire on a 1955 Caddilac?  My horn will start going off when the wheel is turned and will stop as I continue to turn the wheel.  Sounds like a short in the wire.  The car only has 22,000 original miles!  I have everything apart on the steering wheel but my question is at the bottom of the steering column the wire goes up at 90 degrees..  I have attached a picture..  what is inside the 90 degree post off the column??  just trying to understand what I'm dealing with before I take it all apart!!  Unfortunately the wire doesn't just come out of the bottom of the column, this 90 degree move makes me wonder what is in there for it to be wired like that??  Appreciate any help!!
Here are some photos of what it looks like. Attached over it I recall is the Neutral Safety Switch. Be careful not to lose that tiny hold down screw! Clay/Lexi
Bob Kielar
The sleeve was worn on my 55. I went to Ace Hardware with a dial caliper and found a solder copper pipe coupling and it fit on the column shaft. It has worked for ten plus years. I must have posted this on the now closed down Mid-Century CadlIkes forum, man there was a lot of information lost when that was closed.
Keep Cruzin
Bob
Keep Cruzin
1955 Cadillac Fleetwood
Kevin Kenneally
Quote from: Lexi on October 11, 2023, 08:02:07 PMHere are some photos of what it looks like. Attached over it I recall is the Neutral Safety Switch. Be careful not to lose that tiny hold down screw! Clay/Lexi
Pictures a big help, thanks!!
Lexi
