1959 Cadillac transmission intermittent leak
Started by Cadillac Jack 82, October 24, 2023, 10:43:19 AM
Cadillac Jack 82
My 1959 Cadillac has recently been leaking transmission fluid.  I assume its due to the fact that the car sat for a while and wasn't used.  The issue I have is that when I ensure its topped off it'll leak fairly steadily but then stop.  I've read some past posts and I've seen posts saying its the filler tube gasket to the front seal by the flywheel.  Does anyone have any past experiences with this or suggestions?  The leak mainly comes from the front so I doubt its the rear seal.  It also seems to shift fine both with light and heavy acceleration.
CLC Member #30850
1934 Harley VD 74ci "Rosie"
1948 Buick 76S "Lillian"
1950 Cadillac CDV "Doris"
1959 Cadillac CDV "Shelley"
Past Cars
1937 LaSalle Coupe
1955 Cadillac CDV
1957 Cadillac Series 62 Coupe
1964 Cadillac SDV
and a bunch of others...
Jeff Rosansky CLC #28373
It only leaks intermittently??
Wow!! Wish mine would do that  ;)
I'd clean it, fill it, let it run and then climb under to see if you can see the leak's starting point.
Jeff R
Jeff Rose
CLC #28373
1970 Coupe DeVille (Big Red)
1955 Series 62 (Baby Blue)
Dad's new 1979 Coupe DeVille
Cadillac Jack 82
I know its very odd.  Leaked like crazy when I pulled it out.  Checked the level at home and it was normal.  Perhaps my dumba$$ overfilled it????
CLC Member #30850
Past Cars
1937 LaSalle Coupe
1955 Cadillac CDV
1964 Cadillac SDV
Is that a model that is tricky to get the level right?  Anyone with the same model describe how they are checking the level?
Daryl Chesterman
I drive a 59 Deville and the method I use is to start the car and with a foot on the brake, I shift into the first forward gear, wait a few seconds and shift into the second forward gear, wait a few seconds and shift into the next forward gear, wait a few seconds and shift into reverse, wait a few seconds and shift into park.  Get out of the car, leaving it running—lift the hood and remove the transmission dipstick and wipe it clean.  Reinsert the dipstick until it bottoms out on the dipstick tube and withdraw the dipstick and keeping the bottom end of the dipstick down, read the level of the oil.  When  cold it will read about halfway between the two marks, and when hot it should read at the full.  The Service Manual says that when fluid is cold the level should be 1/4" below the full mark.  By running the transmission through the range of gears, the fluid coupling is filled and all of the valve passages are filled, thus ensuring an accurate reading on the dipstick.
Daryl Chesterman
Cadillac Jack 82
Welp still tracing this little gremlin.  She will nearly pour trans fluid then she'll be fine.  After a long cruise today came home to find a nice pond of trans fluid however the dipstick reads full with the engine off.  With it on she'll read 1/4 full.  Shifts fine and no other issues.  Am I using too much fluid or is the front seal failing?
CLC Member #30850
Past Cars
1937 LaSalle Coupe
1955 Cadillac CDV
1964 Cadillac SDV
V63
Generally... The factory recommends checking fluid on a level surface, components operating temperature, WITH the car in park and engine running, (idling).
Verify the stick is seating into the tube fully. Might also verify the stick is a factory one and not a "replacement"  because a replacement could introduce errors in calibration.
Cadillac Jack 82
I'll take a look at it over this weekend when I have her back out from her garage.
CLC Member #30850
Past Cars
1937 LaSalle Coupe
1955 Cadillac CDV
1964 Cadillac SDV
