1928 ? Chassis
Started by Huey, October 28, 2023, 02:30:58 PM
Huey
Guessing around a 1928 located in mukwonago wi. Pics and more info on aaca web site this is too difficult dealing with this here Thanks
Update, thinking it is a 28 Cadillac. If there's some part that may be on it that you could use let me know.151@att.net thanks again
Mike Baillargeon #15848
Quote from: Huey on October 28, 2023, 02:30:58 PMGuessing around a 1929 located in mukwonago wi. Pics and more info on aaca web site this is too difficult dealing with this here Thanks
Huey,   where on the aaca website?
can you post a link?
mike
Baillargeon
#15848
Tom Boehm
1940 Lasalle 50 series
Baillargeon
#15848
jp1gt
Look at the brakes and rear shocks. Also the sensor on top of the diff. Not a 28 or 29. Is it even a Cad?
dn010
Looks like a plug on the top of the differential, not a sensor. The broken cable thread make it appear as if it is a sensor. However it doesn't look like a Cad frame to me either.
-----Dan B.
'81 DMC DeLorean
Huey
Here is a few pics guys
Huey
#7
Has the same door on fender and that same round light as this 29 caddy,motor is caddy not sure what???
Huey
Here's pic of engine, maybe this will help id this thing
jp1gt
This is a weird one. I can tell you what it is not but not what it is!!!!
Huey
Here is a pic of a 29 on hemmings and a pic of the chassis I have it matches exactly if I look at rivet locations rear spreader bar and rear axle. I say it is a 29 but I do not know anything about caddy's just trying to identify it so any good parts can find a new home. Thanks fellas
Huey
Serial number on "mystery motor"
Johan Boltendal #158
Hi that's a '28 Cadillac engine number starting with 300001 ending 320001
 you should find a number on the frame
on the radiator crossmember at the left side, starting with a 3.... as well, to confirm the frame is '28.
Frame nr should be stamped on the left side, facing the engine so to speak.
Huey
Looked all over radiator crossmember for serial. Is it on top surface? Thanks
This is where it is on my '30, left side of the front engine stand, should be in the same place kind off. Johan
Huey
Ahh I didn't really look down there too good I will take a look tomorrow. When you say left you are referring to driver side ? Correct? Thanks for the help.
Indeed drivers side , remembered this morning, I have an orignal'28 parts book, that tells were to find i.d nrs. Looked it up and found;
The chassis nr. is stamped on the upper flange of the RH side bar,directly over the engine support.
This is all I can come up with, good luck finding the nr. Johan
Huey
Well I looked pretty much everywhere I thought it might be the frame must be a bit to rusty for it to have remained visible. I gently sanded and wire brushed and didn't see it. After a while I started thinking I was seeing numbers like looking in the sky at the clouds seeing things haha. Thanks everyone for the input.
