59 heater core
Started by 60eldo, November 03, 2023, 08:40:36 PM
60eldo
 Just wondering how this thing works and correct me if Im rong. So you start your car and when the water gets hot , it opens the valve to let hot water into the core and now you have heat. Whats the valve there for? If no valve the water when it gets hot wood just flow threw the core and you wood have heat. Why is it there.
Jon. Kluczynski
Eldovert
The valve regulates how much hot water is getting through to the core.
Cheers,Pat MacPhail
V63
I think the confusion is that newer cars the heater core is HOT all the time the engine is running at temperature because the HVAC uses it to blend to desired temperatures selected by its passengers.
But in older cars the heater core was only HOT when the driver desired heat and the only real regulation was by fan speed.
As a side comment, I have become aware that modern HVAC AC portion can be greatly improved by NOT allowing the heater side to be hot during excessive hot weather. I will put a manual valve to simply stop the HOT water into the HVAC during our excessive summer (7) months 🥵
Gabe Davis
#3
As per the service manual, the coolant goes from the water pump to the control valve, through the core and back to the pump.
The valve stops the flow of the water through the core so it is not a continuous loop when not in use:
Both of the Defroster and Heater controls can change how much the valve is open:
I had to have the valve in my core serviced about 10 years ago. It bolts onto the core with a rubber gasket between. The gasket had deteriorated and was leaking into the footwell so I had the whole valve serviced as it was all apart.
The bowden cables from the temperature control and the defroster moves the valve open and closed. It has been a long time since I have had it apart, but I think there was linkage for controlling the airflow between the defroster duct and the heat outlet ducts connected here as well.
There is a thermostatic control as part of the valve that helps regulate the temperature by changing the amount of water flow based on the air that has moved through the core.
The core mounts to a plate that mounts to the heater box.
If I had to guess, I'd assume the Heater control opens the valve at the beginning of its throw and then adjusts how much the thermostatic valve can open depending on how far the lever is moved. The Defog control can override the Heater setting and at the De-Ice position and opens the valve fully, regardless of the thermostatic valves feedback. At least that is my interpretation of what the shop manual is saying and how it behaves when using it.
1959 Coupe DeVille
Rosewood with Dover White Top
60eldo
Great info. Im just saying was, is the valve nessesary. I had a 65 mustang long ago, no valve just water in water out. When heat wasnt needed you just side the control from hot to cold, or somewhere in between. And a door wood close eliminating hot air. No valve , no leaks, no expenive part.
Jon. Kluczynski
V63
If your heater core was hot all the time I believe that would be most uncomfortable in summer months. You could add manual heater valves to shut off the water flow to the core
Cadillac Jack 82
If the wire is loose or not adjusted properly it may not be pulling the tab to open the valve.  Had that issue with my 66 Toro.
CLC Member #30850
1934 Harley VD 74ci "Rosie"
1948 Buick 76S "Lillian"
1950 Cadillac CDV "Doris"
1959 Cadillac CDV "Shelley"
Past Cars
1937 LaSalle Coupe
1955 Cadillac CDV
1957 Cadillac Series 62 Coupe
1964 Cadillac SDV
and a bunch of others...
Cadillac Jack 82
Also if someone didnt flush the coolant with the cores open wide there might be an air bubble.
CLC Member #30850
Past Cars
1937 LaSalle Coupe
1955 Cadillac CDV
1964 Cadillac SDV
Quote from: 60eldo on November 05, 2023, 09:08:03 AMGreat info. Im just saying was, is the valve nessesary. I had a 65 mustang long ago, no valve just water in water out. When heat wasnt needed you just side the control from hot to cold, or somewhere in between. And a door wood close eliminating hot air. No valve , no leaks, no expenive part.
Someone must have removed the tap before you purchased that car, as even Ford wasn't that cheap that they would not install a heater tap.
60eldo
  What Im saying is that from factory there was no tap, just 2 4in pipes coming out of the core. Water travels threw and when water heats up you have heat. To shut heat off, simply slide leaver from heat to cold, that closes a door not to let heat into cabin.
Jon. Kluczynski
V63
Quote from: The Tassie Devil(le) on November 05, 2023, 06:56:21 PMSomeone must have removed the tap before you purchased that car, as even Ford wasn't that cheap that they would not install a heater tap.
Apparently ford was that cheap🤣✅, I just tried to find a heater valve for a 1965 mustang 🤣
60eldo
They DONT have valves, they arent nessesary, and they cost 200-300 bucks, for what
Jon. Kluczynski
