Electric wiper motors for 50's Cadillacs
Started by Cadman-iac, November 09, 2023, 12:24:14 PM
Cadman-iac
Hi all,
 There's been several threads about the wiper motors on the 50's Cadillacs, and it seems that most, (almost all) are vacuum.
 I was wondering if anyone has a picture of what an original 56, 57, or 58 electric wiper motor.
 Does anyone know what year the electric wiper motor became available on a Cadillac?
 I find it very confusing why Cadillac continued to use the vacuum motor while the other GM car lines were offering the electric motor.
 Any theories on this?
 Rick
CLC# 32373
PHIL WHYTE CLC 14192
I can only assume that the reason they stuck with the vacuum wipers is that if you were stuck in traffic on a cold wet night with lights on, heater on and radio on plus electric wipers your battery would go flat. Only a guess on my part though. I think 59 was the first year for electric wipers, I could be wrong?
Lexi
Makes sense Phil, as a Cadillac car then had the potential to have more electrical drain on the battery because of additional options available. Interesting and reasoned speculation. Clay/Lexi
V63
I think it was one 🤬 of a trico salesman!!!  🤭
Gabe Davis
Yes, '59 was the first electric year. My '59 CDV has electric wipers.
1959 Coupe DeVille
Rosewood with Dover White Top
Cadillac Jack 82
Agreed with Gabe.  Mine are also electric and its fantastic compared to the 55 and 57 which were vacuum.
CLC Member #30850
1934 Harley VD 74ci "Rosie"
1948 Buick 76S "Lillian"
1950 Cadillac CDV "Doris"
1959 Cadillac CDV "Shelley"
Past Cars
1937 LaSalle Coupe
1955 Cadillac CDV
1957 Cadillac Series 62 Coupe
1964 Cadillac SDV
and a bunch of others...
Cadman-iac
Quote from: Gabe Davis on November 09, 2023, 04:49:19 PMYes, '59 was the first electric year. My '59 CDV has electric wipers.
 So for 59 the electric wiper motor became standard, or was it offered as an option?
CLC# 32373
Cadman-iac
  Was an electric wiper motor ever offered as an option for Cadillac, and if so, when?
 And if one of you guys with a 59 could post a picture of your electric wiper motor, I would be very grateful.
 Another question.
On the 59, did they still use the cables between the motor and the wiper arms, or did they use a linkage at this point?
 At what point did Cadillac switch from the cables to solid linkage for the wipers?
 Thanks for your help. Rick
CLC# 32373
Poncholover
The early wiper motors were just one speed.
The Vacuum units were adjustable & when in optimum condition were really quite good.
Heck, Packard stuck with them until the end.
Flattie Caddy
Quote from: Cadman-iac on November 09, 2023, 08:55:07 PMWas an electric wiper motor ever offered as an option for Cadillac, and if so, when?
 Another question.
To my knowledge Cadillac never offered an electric wiper motor option. Chevrolet did in the 50s (57 I think). Taking a guess I'd say that that was the case as Chevrolets generally didn't have many electric accessories. I believe the 59 Cadillac system is totally different from the vacuum systems ie.the 59 motor won't bolt onto a vacuum system.
No cables on the '59 Cadillacs but the usual linkage.
Jay Friedman
Some years ago I had my '49's vacuum wiper motor rebuilt by www.wiperman.com and it works very well. Probably as well as when the car was new. Yes, the wipers slow down a bit in low vacuum situations like going up a hill, but still wipe well enough.
I did look into converting to electric wipers, but the firm I'm aware of that sells a bolt-on electric motor only offers a 12 volt version.  For a 6 volt car like mine, in addition to several hundred dollars for the electric wiper motor, to power it I would have to buy their 6/12 volt inverter for well over $100, making for an expensive conversion.
BTW: I once read that Studebaker already had electric wipers in the early '40s.
1949 Cadillac 6107 Club Coupe
Decatur, Georgia
CLC # 3210, since 1984
Gabe Davis
#12
Quote from: Cadman-iac on November 09, 2023, 08:55:07 PMAnd if one of you guys with a 59 could post a picture of your electric wiper motor, I would be very grateful.
Here you go! Sorry for the flash - she is tucked away in the garage at the moment.
Bottom left you can see where the pump is for the washer fluid. The larger rubber line comes from the jar and the smaller lines go to the nozzles.
Linkages are all solid rods. Couldn't get the camera through the cowl grill to snap a photo.
Controls:
4 detents - Off - Low - Medium - High
Washer button is momentary but when pressed it moves the wiper speed to Low
Wiper info is in the 1959 Shop Manual in the Body section starting at 15-6.
Quote from: Cadman-iac on November 09, 2023, 08:49:20 PMSo for 59 the electric wiper motor became standard, or was it offered as an option?
I would hazard a guess that electric became standard in 1959. There is no mention of any other type of system in the service manual for that year.
1959 Coupe DeVille
