1980 Eldorado 350 Gas Injector orings
Started by Turboba6, November 26, 2023, 05:34:34 PM
Turboba6
Folks,
Where do these Copper rings go, my Original injectors had only the 3 Top Hat for the Rail and the Rail oring and the Fat injector oring...Thanks!
Do the other bits seem to fit?   If not I wonder if you ended up getting a set for a diesel?  Those did use copper washers.  80 had 2 different styles and what you have isn't the style I know but it could be the earlier version, I know those had a few more connection points than the ones I new.
Turboba6
Hmm, I got the Part number shown in the pic, from this board, and it's Listed as 350 Gas...maybe Bruce will chime in...Thanks
jagbuxx #12944
Crush washers go where the metal lines fit with each other and at pressure regulator.
Frank Burns #12944
61 Coupe Deville Bristol Blue
41 Series 61 6127D Black
16 GTI Gray
03 T-Bird Black
19 Tiffin Phaeton 40AH
07 Corvette Blue
20 MB S450 White
77 Chevy C10
"Whatever the occasion, there
