1960 CDV Radio light and I think I know the answer
Started by gkhashem, December 06, 2023, 12:39:33 PM
gkhashem
I think there are two radio lights.
One when you turn it on and that's inside the radio so removal would be necessary and the dash with it.
The other light is on the outside of the radio and clips into the top. This comes on when the headlights are on. It appears there is little to no room to remove that.
So again the dash would come off.
Am I correct or is there a way to remove radio without the dash removal? It looks like the dash needs to come off to access the bulb(s).
If so, what a poor design!!!
1970 GMC C1500
1992 Oldsmobile 98 (OCA 1st)
1996 Oldsmobile 98
Past Cadillacs
1959 Coupe Deville
1966 Coupe Deville (Sr #861)*
Cadillac Jack 82
Only one light that I know of.  Thats the light that comes on when you pull the light switch.
CLC Member #30850
1934 Harley VD 74ci "Rosie"
1948 Buick 76S "Lillian"
1950 Cadillac CDV "Doris"
1959 Cadillac CDV "Shelley"
Past Cars
1937 LaSalle Coupe
1955 Cadillac CDV
1957 Cadillac Series 62 Coupe
1964 Cadillac SDV
and a bunch of others...
Eric DeVirgilis CLC# 8621
Quote from: Cadillac Jack 82 on December 06, 2023, 01:11:00 PMOnly one light that I know of.  Thats the light that comes on when you pull the light switch.
There's also a pilot light in the center of the dial that illuminates whenever the radio is powered up.
No stereo radio in 1960. AM only.
Michael Petti
Radio can be removed by tsking out the glove box liner. A little tight. But I have done it several times.
Michael Petti
Forgot to mention remove the glove box door also.
gkhashem
How about the speaker? Should that come out first?
1970 GMC C1500
1996 Oldsmobile 98
Past Cadillacs
1959 Coupe Deville
Michael Petti
No need. Be sure to unplug all wires to the radio.  If your radio is not stock check for the connections. Speaker and antenna and power.
59-in-pieces
#7
George,
Indeed, there are 2 lights on the radio. one mounted though the top of the radio to illuminate the face of the dial, and the other inside the radio shows as a red dot which is a "Power On" indicator, on the face of the dial.
The radio is held in place behind the dash by, 1 each specialty round "slotted" nuts in back of the knobs on each side of the front of the radio where the shafts comes through the dash.
There is a short 6" diagonal bracket with a bolt at each end mounted to the left bottom side of the radio, and a short straight bracket with a single bolt attached to the front right of the radio.
There are harness connections, for power, antenna, remote foot control (if the car is so equipped), and the front speaker.
I offer some pics, which I hope will be helpful.
Have fun,
Steve B.
S. Butcher
Cadillac Jack 82
Great pictures.  BTW how hard is it to install the radio foot switch?  Just plug and play?  How does it mount to the floor?  I wouldn't mind this option although they're very few AM stations worth listening to.
CLC Member #30850
Past Cars
1937 LaSalle Coupe
1955 Cadillac CDV
1964 Cadillac SDV
gkhashem
Great pictures Steve, thanks.
I knew about most of this except the mounting bracket on the right side.
I think I can get this out without removing the dash.
1970 GMC C1500
1996 Oldsmobile 98
Past Cadillacs
1959 Coupe Deville
