1941 Master Cylinder Gasket Material
Started by J. Russo, January 07, 2024, 02:42:10 PM
J. Russo
I have the original master cylinder on my 1941 Series 63. I made a gasket with EPDM rubber a couple years ago but it broke down over time.
I read an older post on the forum where some folks use a fiber gasket on the filler cap.
I haven't found any pre-cut gaskets for this master cylinder. I did find fiber gasket material online, but could anyone recommend a specific brand/type that they use?
Thanks!
John Russo
CLC Member #32828
Rossoroo
Most north American manufacturers used that style of master cylinder for a long time. First thing I would do is find an established parts store and see if they have something in stock that would fit. Failing that,
most auto parts stores of any size will sell gasket material kits or you may be able to just buy a sheet of cork gasket material on its own and make your own.
49-6269 My First Caddy
J. Russo
Quote from: Rossoroo link=msg=552696 date=1704662001
/quote]
I have a sheet of cork material. I don't know if cork is the right material to use with brake fluid.
John Russo
CLC Member #32828
harry s
John, My car has a brass flat washer. I have seen this type on others also.
Harry
Harry Scott 4195
1941 6733
1948 6267X
2011 DTS Platinum
J. Russo
John Russo
CLC Member #32828
harry s
Those folks have lots of parts that work on our Cadillacs.
Harry Scott 4195
1941 6733
1948 6267X
2011 DTS Platinum
