56-57 hydramatic
Started by Bronze, January 11, 2024, 07:47:20 AM
Bronze
Quick question for the knowledgeable people on the forum: Is it an easy thing to put an -56 tailhouse extension on a 57 transmission and thus use it in a 56 car? If so, any other things to be done while the extension is off, Governor clean-up ?
BR
/Martin
Lexi
While I can't answer your question directly, I believe one of my older '56 Caddies had a 1957 Hydramatic case with a 1956 tailstock as well as perhaps a 1956 bell housing. I never did any work there myself, but was done years earlier by a previous owner who probably got fed up with transmission problems of his '56. I don't recall any other changes or issues. I believe the transmission case wasn't even Cadillac, (perhaps Oldsmobile), but was a hydramatic. That set up permitted the use of the original driveshaft-as I recall. So this would seem to be in the "definite maybe" category. Clay/Lexi
dn010
According to the interchange book, for 1956 an Olds 56 "o" bolts up, extension is different and you need to modify the driveshaft. It does not say that the 1957 can be made to fit like it does for 58, so I'd assume there is some sort of difference that makes so it doesn't work out that easily.
-----Dan B.
'81 DMC DeLorean
Lexi
Quote from: dn010 on January 11, 2024, 09:45:02 AMAccording to the interchange book, for 1956 an Olds 56 "o" bolts up, extension is different and you need to modify the driveshaft. It does not say that the 1957 can be made to fit like it does for 58, so I'd assume there is some sort of difference that makes so it doesn't work out that easily.
Interesting, as I thought the worn spec plate did say "O", which I assumed was Oldsmobile. I thought the drive shaft was stock, but can't say for sure. Clay/Lexi
The extension is easy to interchange, but you also need to switch the output shaft. It's more or less a major job. You could just switch the output shaft with the reverse drive flange but how will you check if the selective thrust washer is the right one?
Bronze
Roger, Do i understand it right: With the extension housing off and having removed the governor housing with the governor, I could remove 2 snap rings and then pull out the output shaft with the reverse drive flange and selective thrust washer ?
But you then point out that i will not know if it is the right selective thrust washer. Pardon my ignorance but i don't know right from wrong...in this case :) If i pull the 56 shaft with reverse drive flange and selective thrust washer and put the assembly in the 57 trans, can i not assume that the selective thrust washer will be correct?
Bronze
Ahh, i get it, the thrust washer is like a shim that is specific to each unit to take up any play...right?
dn010
Quote from: Bronze on January 11, 2024, 04:09:19 PMAhh, i get it, the thrust washer is like a shim that is specific to each unit to take up any play...right?
This is correct.
-----Dan B.
'81 DMC DeLorean
Bronze
And Roger already answered the first question back in 2021. Thanks Roger ! ;D
Quote from: Roger Zimmermann on September 27, 2021, 01:24:54 PMI went to my shop this afternoon. To exchange the drive shaft, the whole internals must go out because the reverse drive flange diameter is larger that the rear case diameter...
